budget build for auto x
Old Mar 1, 2016 | 12:08 PM
Ben_'s Avatar
Default budget build for auto x
looking to spend 800-1100 on the parts to make my engine better
want to run N/A for now and maybe boost 6-12 psi later if im still hungry for power
currently have
d15b7 runs ok smokes pulls well
a6 cam
doing y8 trans swap asap
was thinking
bisi regrind on the cam
cost - 400$
get a junkard b7 head mill .03
cost - 50$ plus machining
junkyard z6/y8 block and crank
new oem rods/pistons
cost - ???
gaskets & bearings & y8 gasket
cost - $$$
Old Mar 1, 2016 | 12:49 PM
Ohmega's Avatar
Default Re: budget build for auto x
So what is your question?
Also, throw your "PSI" goal out the window. PSI means nothing in regards to turbochargers.
Old Mar 1, 2016 | 12:55 PM
Ben_'s Avatar
Is this doable for 700-1100$
I need to make parts list and budget bro I'm doing this help me pick parts
Old Mar 1, 2016 | 01:07 PM
Ben_'s Avatar
I will be installing said parts so no money spent on labor
Old Mar 1, 2016 | 01:32 PM
Ben_'s Avatar
D17 Rods Honda D17 Connecting Rods H Beam D17 Rods 5 394 Long 19mm Pin ARP2000 | eBay
403
01 05 Honda Civic 1 7L D17A2 D17A6 Engine Pistons and Rings Main Rod Bearings | eBay
112
Amazon.com: Fidanza 191161 Aluminum SFI Approved Flywheel: Automotive Amazon.com: Fidanza 191161 Aluminum SFI Approved Flywheel: Automotive
160
Amazon.com: EXEDY 08022 OEM Replacement Clutch Kit: Automotive Amazon.com: EXEDY 08022 OEM Replacement Clutch Kit: Automotive
89
Web Cam Inc. - Performance and Racing Camshafts / Honda CRX Si / D 15 B 2 (88-91) SOHC 16v Timing Card
360
Amazon.com: ARP 2084305 High Performance 12-Point Cylinder Head Stud Kit: Automotive Amazon.com: ARP 2084305 High Performance 12-Point Cylinder Head Stud Kit: Automotive
114
Amazon.com: Evergreen HSTBK4028-2 Head Gasket Set Timing Belt Kit 92-95 Honda Civic VTEC 1.6 SOHC D16Z6: Automotive Amazon.com: Evergreen HSTBK4028-2 Head Gasket Set Timing Belt Kit 92-95 Honda Civic VTEC 1.6 SOHC D16Z6: Automotive
88
makes for 1326$
little too much. is this missing anything???
Old Mar 1, 2016 | 01:34 PM
Ben_'s Avatar
the d series calculator says this will be 9.25 comp ratio with no mill of head
Old Mar 1, 2016 | 01:38 PM
WiscoEx's Avatar
Have you spoke with your machine shop about the cost? A better idea of where you are in your goal will depend largely on those costs.
Ben_'s Avatar
don't have one. i'm located near SLC
Old Mar 1, 2016 | 01:55 PM
NotARaCist's Avatar
I never narc'd on nobody!
Why are you looking at D17 parts? Completely different motor, not compatible. Why have you not read the FAQ sticky?
Old Mar 1, 2016 | 01:56 PM
Ben_'s Avatar
why not do d17 crank and oil pump and such for more displacement
Old Mar 1, 2016 | 02:03 PM
Ben_'s Avatar
if i swap the whole d17 rotating assembly out of a junkyard car that has been wrecked and use a d16 block and b7 head those parts should match
Old Mar 1, 2016 | 02:13 PM
NotARaCist's Avatar
Because displacement isn't the only thing you should care about. Stroking out a D16 would lower your redline, which cuts out the range where these motors are known for making most of their power, and that's all assuming you don't run into issues with the pistons poking too far above the deck and causing P2V issues. There's just not enough to gain from it for it to be worthwhile.
Old Mar 1, 2016 | 02:16 PM
eghatch9295's Avatar
Stancetard Hate Monger
tires tires tires tires tires tires suspension brakes. you clearly do not understand autox.
Old Mar 1, 2016 | 02:25 PM
98civdx's Avatar
Master Detailer
I came in thinking this.
Stop trying to make more power, focus on what he mentioned.
have you even autox'd the car yet?
Old Mar 1, 2016 | 02:26 PM
Ben_'s Avatar
fair enough back to the original plan
found a machine shop so heres the new build
rebuild b7 head
cam - 360 from web cams who does bisi's cams lol
valve job - 225
surface and mill .03- 50
evergreen valves - 105
head gasket & bolt kit - 105
block
junkard z6 probably
deck plate hone - 185
rebuild kit - 305
Amazon.com: OK4029/2/0/0 96-00 Honda Civic VTEC 1.6L SOHC 16V D16Y5 D16Y7 D16Y8 Engine Rebuild Kit: Automotive Amazon.com: OK4029/2/0/0 96-00 Honda Civic VTEC 1.6L SOHC 16V D16Y5 D16Y7 D16Y8 Engine Rebuild Kit: Automotive
flywheel and clutch
250
this comes to 1580
Old Mar 1, 2016 | 02:29 PM
Ben_'s Avatar
you clearly dont understand situation bro
set up is as follows
15x7 rpf1 re71r 205
progress cs2
poly bushings all around
doing si full brake swap soon have parts just need to install
full exhaust w/ new cat
ignition system tune up
d16 trans soon with flywheel/clutch
Old Mar 1, 2016 | 02:32 PM
Ben_'s Avatar
oh did i forget to metion integra ls front sway and eibach 25mm hollow rear as soon as i get control arms
Old Mar 1, 2016 | 02:36 PM
White_EG1's Avatar
Originally Posted by Ben_
d15b7 smokes
Fix this first
Old Mar 1, 2016 | 02:37 PM
Ben_'s Avatar
i think ill fix it by throwing it out and making a new engine. the thing is wore out and now ticks its got 220k on it its time for it to die
Old Mar 1, 2016 | 02:45 PM
98civdx's Avatar
Master Detailer
How many events have you done with the current setup?
Why are you looking to turbo it? I'm just curious.
have you considered a simple B swap instead?
And to your original question. I'd take a looking a vitara piston/eagle rod build. Cheap, proven, and reliable.
Old Mar 1, 2016 | 02:48 PM
Ben_'s Avatar
not looking for turbo right now. if i want turbo ill take the engine i make now put studs rods pistons w/e but right now if i can get a RUNNING d ill think about turbo later. I still have races to attend lol
this is my 3rd year right now 60 events maybe. the car has only 3 events on it but it feels stronnnnggggg
b swap is expensive and hard. with using my b7 head i dont even have to touch the wire harness or tune or anything if i don't run crazy high compression
BUDGET BUILD im not a millionaire i saved a few g's last summer working at a copper mine so now im spending it all at once
Old Mar 1, 2016 | 02:50 PM
Ben_'s Avatar
vitara pistons alone are almost the same price as my machine shop quote just saying
Old Mar 1, 2016 | 02:51 PM
Ben_'s Avatar
then you buy rods bolts turbo tubing ecu wire harness put it all together blah blah blah i want some all american cheap greasy fast horsepower
Ben_'s Avatar
130 whp would be ******* fantastic
Old Mar 1, 2016 | 02:54 PM
98civdx's Avatar
Master Detailer
https://www.speedfactoryracing.net/e...ods-d16-75-5mm
I definitely understand staying on a budget. If you plan to tune, I honestly wouldn't do anything other than an OEM rebuild. You'll get the full potential out of it, especially if you upgrade the cam.
