Civic 95 4dr Door lock problem (solved)
Old Mar 1, 2016 | 02:19 AM
Mil Mercs's Avatar
Default Civic 95 4dr Door lock problem (solved)
anyone experience the same? need help to overcome this
Old Mar 1, 2016 | 05:11 AM
Former User's Avatar
Default re: Civic 95 4dr Door lock problem (solved)
What's the problem?
Old Mar 1, 2016 | 06:37 AM
Mil Mercs's Avatar
see the **** making strong vibration and strange noise when lifted up (door unlocked). i can't lock the door manually with the key. it will kick back the key to home position. if i put a strong force to turn the key, it will make the same vibration and noise.
Old Mar 1, 2016 | 07:44 AM
It's a mechanical problem with the door lock mechanism. Remove door panel and inspect the lock rods and latch.
Old May 9, 2016 | 08:59 AM
Mil Mercs's Avatar
UPDATE:
I found out the lock actuator was broken but they have nothing to do with the problem. the only thing i've done is to adjust the the **** shaft which is connecting to the joint, put it in lower position (in red circle). now it's work.
Dan110024
Jan 5, 2012 07:31 AM
PFCAcosta
Jan 24, 2011 05:56 AM
lead23
Feb 23, 2008 09:12 PM
richirichi
Aug 26, 2004 03:39 PM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
