The engine is coming out to be put in a minibuggy (the car overall is trashed) and the engines that have that jackshaft won't work...makes my half shafts too short. That D15 in the eBay auction I can mount the tranny output center line and keep my shafts as long as possible.
My next issue will be making sure the thing has compression. I'm not buying the car if I can't crank it...do they have a start relay terminal I can jump to turn the engine over? If it's got decent compression I'll just break the column to unlock it and get it home, but if the engine is locked up or something I don't want to commit to buying through damaging it.
Lastly, just anything you guys can tell me about this engine would be wonderful! I'm fairly new to Honda's cars...I'm more of a motorcycle guy...and I'm absolutely virginal when it comes to Civics.
re: 95 Civic Coupe EX, Manual - Engine/transmission questions
I do sincerely appreciate the links to those articles...I'm actually reading through most of the D16-related stuff I can find...BUT none of them really tell me with certainty that none of them have that funky jackshaft going across the back.
That's my problem. I'm told that's a B18...not sure...but several of the engines I've seen on eBay seem to have that jackshaft going across the back. Won't work for me. If this '95 EX has that kind of transmission setup, there's no point in me bothering with the car.
Reason: Picture fixed
How about the typical manual transmission attached to the typical D16? The engine is less a concern to me as it is how the drive shafts attach to the transmission.
Re: 95 Civic Coupe EX, Manual - Engine/transmission questions
If there's a way to get it to start then maybe, but I'm worried he'll jack his price up if it turns into a running car. Mostly all I'm concerned about up front is cranking it to make sure it's free and has compression.
After I get it home I'll bust up the column to deal with trying to start it. The buggy will be start button only so I'm too worried about conserving anything there.
Originally Posted by Makenzie71
Which ever is more convenient. I would assume the battery in the car (with jumper cables).
To crank the starter, you must supply ground to the starter armature housing and battery voltage both to starter motor terminal B and to starter solenoid terminal S.
bummer. I was hoping for a remote relay where I could just jump the terminals. Oh well...maybe I can get the key cylinder to unlock with a jiggler.
Can the speedometer be calibrated? I'm considering using the factory gauge cluster mostly for the ease of a speedometer, but I'm going to be running 29" tires....nearly a full 6" taller than stock.
