the perfect turbo
Lookin for suggestions on a turbo. Its going on a fully built, i.e. sleeved block, forged internals etc, b18c1. Straight line speed is my goal specifically the 1/4 mile but a lil street racing in between
. KLM forward face manifold, tial Q60, Tial v50, KLM 1000hp intercooler and DSS level 5.9 axel/shaft setup.
As said above your ET and/or power goal is the first criteria. The new tech billet 62 and 64 mm units from all the major turbo suppliers are really producing the numbers and give a decent enough powerband to double up for street use.
The units below are all 700 - 850 hp capable (some a little more)
PTE 6062 Gen 2
PTE 6262
PTE 6266 Gen 2
PTE 6466
BW S362 SXE
BW S364 SXE
Comp 6262
Comp 6265
Xona 7864
Xona 7865
Xona 8267
PTE 6062 Gen 2
PTE 6262
PTE 6266 Gen 2
PTE 6466
BW S362 SXE
BW S364 SXE
Comp 6262
Comp 6265
Xona 7864
Xona 7865
Xona 8267
you need a turbo match the power band and power goal you want
you need to calculated compressor map for the motor need
and i you can buy couple different turbine housing a/r size to found the best power band on a dyno
The new Xona Rotor sub 60 mm turbo's also look sweet !
Soon to be set up=forward face manifold, 1000hp intercooler, 2000cc injectors same fully built gsr
For a street/strip car. Gen. 2 CEA Ball Bearing 6466 Precision hands down. Myself I am running a Gen 2. DBB CEA 6870 but have a S2000 and its a bit more of a drag car. The new SXE Borg Warners are pretty sick too. But I would get something in the 62-64mm range that is rated for 800-900 range.
I had 500+hp on my integra and ran 10s on a GT3076R!
I run 10.90's @ 140 mph with a Holset HX40, 84mm LS/Vtec in a full weight EG plus a 6 point cage (2500 lbs) on a 24.5 x 8.0 slick.
Our track is really poor so on a better track like you guys have access to, the car should be even quicker ET wise.
To be honest, you should be able to get your current setup a lot closer to the 10's than where you are at the moment. Maybe you need to give us more info on your setup in terms of fuel, boost and tyre size.
Correct you are, around 600 on a fair dyno, a little more probably on a Dynojet. Don't mean to hijack the OP's thread, but it validates my point that his current setup isn't working for some reason.
My 10.90 was with a poor 1.78 60ft, the average "good number" for my car. Hoping that the new 4-port solenoid and softer wastegate spring will allow me to come off softer and get into the 1.6x range and drop the ET to 10.50's or so...
For the OP's setup the MPH is really low, unless he is running bad fuel and/or low boost. The 60-1 is an old school turbo but it should still get you to over 500whp based on the 60 lb/min flow rate.
My ek hatch gutted , no cage with only 400hp on 23" slicks was able to run a 10.94@127 .....
Are you guys really trying to compare a naturally aspired V8 powerband and power to weight ratio vs a forced induction I4 powerband and power to weight ratio?
PTE 6062 Gen 2
PTE 6262
PTE 6266 Gen 2
PTE 6466
BW S362 SXE
BW S364 SXE
Comp 6262
Comp 6265
Xona 7864
Xona 7865
Xona 8267
PTE 6062 Gen 2
PTE 6262
PTE 6266 Gen 2
PTE 6466
BW S362 SXE
BW S364 SXE
Comp 6262
Comp 6265
Xona 7864
Xona 7865
Xona 8267
Garrett GTW, GTX, GT or any Borg warner series.
The sad part is the founder of PTE worked for Garrett for almost 2 decades in the field and in engineering... he obviously didn't learn a whole lot during that time LOL!
I personally run Holset's on my cars, and I'm in the process of upgrading my HX40 to "6466" equivalent specs, rather than going out and buying a PTE.
Not sure why I left off Garrett on my initial list, a GT3582, GTX3576R or GTW3476/3684 are all good options too.
Its like if I was working for soft drink company and the main sweetener was Cane sugar but then I heard about this cool substitute called high fructose corn syrup, its easy to make its everywhere and it its cheap and bad for your health. However all I care about is making fast money, so open my own business selling soft drinks made with corn syrup. Comparing turbos to soft drinks but hey you get my drift. PTE is cheap quality **** sold at the price of good quality parts.
