91 integra codes 7 and 16
hey all, was having all the symptoms of a loose high idle valve the other day so i took it off and cleaned it and tightened it down. when i went to start the car i was having codes 7 and 16 blink at me. i checked injectors and saw an o ring was leaking so i replaced all the seals on all 4. I also ordered a TPS but have not installed it yet as they dont really ever god bad from what i have researched. I am still getting both codes and a weak idle. any suggestions
When I rebuilt my iacv I tightened it all the way down. Haven't had issues. Code 7 is throttle position I believe and 13 barometric pressure? I recently did a tps on my car. It's simple to replace but very touchy to calibrate! I belive it needs to be set at 1.5 WOT (wide open throttle) FIRST then .5 on closed throttle. Trust me it's not easy! You only need a multimeter and a ton of patience! Code 13 though, not familiar with its placement on the car, or what happens when it fails.
410ruga
Mar 25, 2014 12:07 AM
wakaranai
Mar 23, 2010 12:41 PM
mikeunreal2
14
Feb 9, 2006 01:51 PM
