Accord V6 3.0L Ignition Coil "PROBLEM"
How check a ignition coil in Honda Accord V6 3.L (3 Pin)
How test the ignition coil?
Ignition coil (maybe is bad), no spark, (check engine) engine light in dash is OFF
Thanks.
Thanks.
Get yourself an HEI spark tester. Connect it to the end of the coil like a spark plug, then ground it to the engine. If it doesn't spark, your coil is probably toast.
Also check the wiring to the coil in question for power.
Precisely what I want is to know which method to check the voltage signals? that go to the ignition coil from the main wiring.
That's exactly what I want to check. If the 12-volt power is coming to the ignition coil through the three pins on the coil?
Thanks for your support
