What turbo to run on a f22b1
I have a 95 accord ex that I am boosting and I was wondering what your guys opinion was on a turbo for it. I want to have 300-350 whp and I want it to be reliable, as its my DD. Thanks in advance.
Well you could buy a cheap ebay turbo that advertises some hp that you're looking for. If you want to do it the right way, IMHO you need to look at compressor maps, do some research, read some threads on whats been done and was is proven to work.
If you want reliability and to DD then you should be looking at internals (rods/pistons). Probably even more important than that is a GOOD tune. A great build can be torn apart by a bad tune/tuner.
I am not very familiar with accords, I used to rock a f22 but it was NA.
However I am fairly certain 300 HP is not a problem with stock rods and pistons, cant imagine that they have weaker rods then b series.
Ive heard that i can swap the pistons with the k24 nd the heads off a h23 it put out over 400 whp how true is dat i seen a cheap turbo on ebay to run with that setup with intentions of using it as a dd car..
you may want to consider just doing a h22 swap as it will be easier to find parts
b16vt3c
Feb 3, 2010 07:45 PM
