innovative hydro
Old Feb 17, 2016 | 05:37 AM
Joe Yaerrd's Avatar
Default innovative hydro
Anyone ever use the innovative hydro swap? Have any pics?
Old Feb 17, 2016 | 12:16 PM
shopa's Avatar
Default Re: innovative hydro
I purchased this mount and will install soon
Have some pics mounted...
Old Feb 17, 2016 | 01:54 PM
Joe Yaerrd's Avatar
I'm buying the hydro conversion I just wanna see the bracket mounted on the car
Old Feb 17, 2016 | 03:42 PM
br8crumb's Avatar
i do not have any experience other then the hush performance conversion kit... but rule of thumb if you want to use the mechanical kit to convert mechanical-hydro.... they are made for stock clutches. if you choose to use a mechanical kit, and a aftermarket clutch with a heavier pressure plate etc, you run the risk of stretching the cable and/or snapping the pedal assembly. lots of complaints/information out there and if you email them they will tell you the same thing. the mechanical kits are made for stock clutches.
if you are set on using the mechanical setup though, i would strongly suggest hasport over innovative. i have nothing against innovative but the design hasport has is much better. both are made good but hasport has a better design in the angle it sits.
personally would either stay cable or use the hush performance kit to convert 100% to hydro
Old Feb 18, 2016 | 07:17 AM
solorex's Avatar
I bought this innovative bracket last year: https://www.innovativemounts.com/Sea...ts.asp?Cat=206
It works absolutely fine with a Exedy Stage 1 Clutch. Tight clearance with a stock front cross-member but it just clears.
The new HAsport bracket with the Master Cylinder looks good, but I would stay away from the mechanical one (it's got too much flex in it), I'd say the innovative one is better.
Like above though, I wouldn't be using an unsprung or heavy duty clutch, your pedal effort will be heavy with the mechanical conversion.
Everyone says the Hush conversion is good, but honestly it is a PITA to install and you lose your air ducting to the door.
Old Feb 18, 2016 | 08:23 AM
Joe Yaerrd's Avatar
Yeah I would go cable but where I'm at there really hard to come by now ...solorex can you post some pics...I would go hush but 3 400 ehh and some people say the pedal is rough blah blah...If anything I would try to take the whole system out a eg ...has anyone done that? Like pedals full system. .I feel that's the best way
Old Feb 19, 2016 | 12:31 AM
v4lu3s's Avatar
RTFM
Make sure you reinforce the firewall where you mount the pedal and cylinder to avoid flexing of the sheet metal.
1320king
Transmission & Drivetrain
Feb 20, 2013 09:51 PM
92integracer
Oct 6, 2009 04:29 PM
B16A1-EF9
Feb 19, 2004 08:58 PM
crx1856
10
Nov 11, 2003 02:59 PM
dlric
Oct 22, 2002 08:21 AM
