00 ej8 cell p1508
Old Feb 15, 2016 | 08:11 PM
antwat904's Avatar
Icon4 00 ej8 cell p1508
I have eliminated all of my codes on this vehicle except the p1508. I purchased on from another fellow Honda guy but it was old and figured if 25 gets it going why not. It still throws the code. the motor is a d16y8 running on p2p. I ran it for a while to get all the coolant flowed through the motor and ran the heater to flush the heater core. I am still only getting that code. incosistant idle with slight accel. not to mention if I go to higher rpm and press in clutch it will drop and die sometimes. this is extremely aggravating. any help is deeply appreciated. also like to add the one that came on the car looked brand new. also did a ecu swap and received same code.
Old Feb 15, 2016 | 08:20 PM
Former User's Avatar
Default Re: 00 ej8 cell p1508
How many wires does the IACV have - 2 or 3?
Auto or manual transmission?
Old Feb 15, 2016 | 08:26 PM
antwat904's Avatar
Two wire and manual trans.
Old Feb 15, 2016 | 08:28 PM
Unplug the IACV.
Turn key to ON(II).
Measure voltage to body ground at the Yel/Blk wire pin in the connector.
What's the reading?
Old Feb 15, 2016 | 08:29 PM
NotARaCist's Avatar
I never narc'd on nobody!
Pull the IACV, clean it, reinstall it, then re-bleed your coolant. Tell us exactly how you're bleeding your coolant.
Old Feb 15, 2016 | 08:33 PM
P1508 indicates an electrical problem.
Old Feb 15, 2016 | 08:49 PM
antwat904's Avatar
How are you suppose to bleed your coolant properly for installation?
Old Feb 15, 2016 | 08:51 PM
antwat904's Avatar
Also mine isn't black and yellow I have a green and black/silver
Old Feb 15, 2016 | 08:54 PM
Post a picture of the IACV connector and its wires. You may have the wrong connector plugged into the IACV.
Your IACV connector should have Yel/Blk and Blk/Blu wires.
Old Feb 15, 2016 | 09:23 PM
antwat904's Avatar
Will look tomorrow to make sure... and just making sure that is for a obd2b wiring harness
Old Feb 15, 2016 | 09:25 PM
Diagram is for OBD2b 99-00 Civic EX with MT.
Old Feb 16, 2016 | 04:45 AM
antwat904's Avatar
Lmao okay it had the wrong plug on it... next question not cell codes I where does the green wire with black and silver go?
Old Feb 16, 2016 | 04:52 AM
tony_2018's Avatar
Fish Twig
grn/black/silver?? No, each wire either has 2 color codes or a single color.
Old Feb 16, 2016 | 05:31 AM
antwat904's Avatar
2 wires
1 green
2 black with silver
Old Feb 16, 2016 | 05:56 AM
Post a picture. It's either for the radiator fan switch or the power steering pressure switch.
Old Feb 16, 2016 | 06:07 AM
antwat904's Avatar
Will when home also have a one wire plug that is black/red
Old Feb 16, 2016 | 07:35 AM
Contribute to the forum by posting the requested pics of all connectors discussed in this thread.
Old Feb 16, 2016 | 08:04 AM
antwat904's Avatar
I will just have to get home after 5pm cst. And thank you so much for all the help so far.
pjmek
Oct 25, 2012 04:22 PM
SIRIUS VTEC
25
Aug 23, 2011 08:13 PM
gsrauto98
May 28, 2010 12:04 PM
