ek9 type r build
Old Feb 15, 2016 | 04:04 AM
blue1.6eg's Avatar
Default ek9 type r build
Well I sold my 99 ebp em1 and pick this ek9 up last June. I'm working on just cleaning everything up right now I added the carbing bar spoon intake and a few other things.
Old Feb 15, 2016 | 11:51 AM
Eddie's Avatar
Master Ninja
Default re: ek9 type r build
Very nice OP
And this is not tech.
Old Feb 15, 2016 | 12:24 PM
tony_2018's Avatar
Fish Twig
So whats the problem?
Old Feb 15, 2016 | 01:23 PM
blue1.6eg's Avatar
If somebody wants to move it that would be fine I guess I could have put it into introduce yourself but I have been a member for a little bit so I figured against it
Old Feb 15, 2016 | 04:39 PM
NotARaCist's Avatar
I never narc'd on nobody!
Boys and girls, this is what we call a unicorn. Someone on this forum, talking about their EK, when they do actually own an EK. Take note - this happens like, once every few years.
That being said...this is a technical forum. Just say you're making it a build thread, and I'd wager the mods will give you some leeway. If you're just posting to show though, then that's what the appearance forum is for.
Old Feb 16, 2016 | 03:38 AM
blue1.6eg's Avatar
ok well this is going to turn into a build thread I can't figure out how to change the title of my thread but thats fine people who check it out will get to follow.
here she was as it sat in Japan back in may 2015!
The wait was long and absolutely horrible the car then arrived in june! And first thing was first I started to tear it a parts for cleaning and inspection.
I know that shift **** is horrible I changed it out don't worry!
There was a couple things I wanted to clean up right away. as mentioned the shift **** and the engine bay.
Old Feb 16, 2016 | 03:45 AM
blue1.6eg's Avatar
I wasn't a big fan of the engine bay. The valve cover needed repainted and other little things need cleaned up like a weird grounding kit behind the battery. lots of extra ground wires etc.
the whole car was nasty with this black stuff all over it. so I used autoglym super resin polish on the whole car a few times and i still need to do it a few more too but you will see in later up dates.
I started tearing the interior out to check for rust and what not. Just give it a good cleaning
so far so good. I started to undercoat the living crap out of it. I used Rust check (red can for penetration between crevasses) and (green can for a coating). Canadian product and its great i use it on all my vehicles our road salt and salt in the air is horrible where I'm from in Canada.
Old Feb 16, 2016 | 04:00 AM
blue1.6eg's Avatar
and I can't seem to upload any more photos so I will continue tomorrow and if a mod could change my title to include (build) that would be great
Old Feb 16, 2016 | 05:20 AM
Eddie's Avatar
Master Ninja
So much want
Old Feb 16, 2016 | 11:09 AM
blue1.6eg's Avatar
Originally Posted by RI5ING SUN
So much want
Thanks I'll post more tomorrow
Old Feb 16, 2016 | 05:30 PM
blue1.6eg's Avatar
a bunch of parts I picked up before the car even arrived. Turned out the timing belt was changed not long before I got the car so I will kept this stuff for the next change.
after a quick wipe down.
my seats were laying out in the sun to dry after a good cleaning.took them almost 3 days to dry
Old Feb 16, 2016 | 05:44 PM
blue1.6eg's Avatar
Default Re: Em1 to Ek9 build
Then some "over night parts from japan" showed up. Which i realised when you live in Canada its more like two month parts! And a lot of people will say these are a waste of money I know but I don't mind spending money on a ek9.
Then I figured I would just change everything. So I thought I would give these a try and Im actually very happy with them the fitment was perfect.
then i started stripping the valve cover
Old Feb 16, 2016 | 05:49 PM
sr20paisa's Avatar
the outside is showroom fresh
Old Feb 16, 2016 | 05:50 PM
blue1.6eg's Avatar
Then I got the interior pretty well all back together which was way faster then taking it apart.
Old Feb 16, 2016 | 05:59 PM
wannabe_itr's Avatar
Im assuming youre not in the states?
Old Feb 16, 2016 | 06:02 PM
blue1.6eg's Avatar
no Canada. One good thing we have going for us.
Old Feb 17, 2016 | 06:42 AM
blue1.6eg's Avatar
got the valve cover all done I used 2 coats vat high heat primer and 3 coats vat high heat wrinkle red.
as you can see its not honda red but it looked a lot better then the colour that was on it.
Then i started to install my new hoses but i ran into some issues
Old Feb 17, 2016 | 06:47 AM
blue1.6eg's Avatar
The Defi gauges that were in my car were oil temp and coolant temp. The upper hose had a splice connector in it. As you can guess I didn't want to cut a piece out of my new spoon hoses. So I slapped the old on back on. my plan is to take the upper rad house off the head, and there is a good spot to drill and tap to allow for a sensor then that will clean up the bay a lot more. I didn't do it at the time because i didm thane the tools to do it and I was about to drive the car across Canada 5000km (3107mi) so I needed to get it back together.
Old Feb 17, 2016 | 06:50 AM
blue1.6eg's Avatar
So I cleaned the bay up quick the best I could with what I had till I got home. I painted my rad/a/c brackets black. Then changed out a lot of bolts to stainless.
Old Feb 17, 2016 | 07:31 AM
Eddie's Avatar
Master Ninja
Valve cover came out nice man.
I'm surprised the rear seats don't have the red stitching.
Old Feb 17, 2016 | 07:32 AM
blue1.6eg's Avatar
Thanks I'm happy with it considering what it did look like.
no ek9 came with red stitched rears. I believe just the integer did. They are the same style material as the fronts tho I really like them.
Old Feb 17, 2016 | 08:48 AM
Eddie's Avatar
Master Ninja
Ah interesting. Everything looks well taken care of even more now that you gave it a good cleaning.
Old Feb 17, 2016 | 06:10 PM
blue1.6eg's Avatar
Thanks. I'm trying to clean it up the best I can, I plan on keeping this car for a long time
Old Feb 17, 2016 | 09:02 PM
sr20paisa's Avatar
now the inside is showroom fresh
Old Feb 18, 2016 | 06:34 AM
blue1.6eg's Avatar
Thanks I drive it once maybe two times a week I'm going to try and keep it road/show car
