Speedometer not accurate.
Old Feb 13, 2016 | 07:38 PM
Highny's Avatar
Default Speedometer not accurate.
Hi guys,
I just swapped my speedometer to one with a tachometer. After putting it all back together, I drove around to discover that my speedometer is off(according to my phone's GPS). I'm using 175/70R13 tires which is within specs. I was wondering if there is a way to correct it.
Any help would be greatly appreciated.
PS: random question, does anyone know if oxyacetylene welding would work/hold exhaust hangers?
Thanks!
Old Feb 14, 2016 | 10:26 AM
v4lu3s's Avatar
RTFM
Default Re: Speedometer not accurate.
what car, transmission, and cluster are you using? how far off is the speedo to gps?
Old Feb 14, 2016 | 11:08 AM
Highny's Avatar
Totally forgot to mention in my original post.
It's a 1991 Civic HB DX. 5 speed manual. With a cluster swap from a 1990 Si, but I kept the part that connect to the speedometer cable, therefore keeping my original Km. Speed difference is:
Gps/speedometer (km)
35/40
100/107
120/135
Roughly like that. Hope this helps.
Old Feb 14, 2016 | 02:03 PM
Ameedoe's Avatar
Is it faster or slower?
My 91 si reads 67 when gps says ~65. It gets worse the faster I go.
This with 195/50/15
I also have some 205/50/15 and these read slower.
65 when gps says I'm going ~68
It's not off by too much to worry about imo.
Just get different size tires next time.
At least your speeder doesn't go 360 degrees like a friend of mines did.
Doh!
Old Feb 14, 2016 | 02:31 PM
Highny's Avatar
My civic thinks it's going faster than it is. So speedometer reads 135km/h but Gps say 120km/h.
Old Feb 14, 2016 | 06:04 PM
v4lu3s's Avatar
RTFM
I am wondering if the speedo is calibrated to the Si transmission/final drive which would lead to the incorrect reading.
Old Feb 14, 2016 | 08:28 PM
Ameedoe's Avatar
I forget, but I think speedo cables, trannys and speedometers are unique to one another.
Old Feb 14, 2016 | 09:06 PM
Highny's Avatar
That's the thing, I kept the part that connect to the speedometer cable when swapping the dash clustef. So in a way, the speedometer haven't changed. Since the speedometer is a machically operated, it shouldn't be effected by the electrical side of the dash cluster...
Old Feb 16, 2016 | 08:36 PM
br8crumb's Avatar
It's a cable driven speedo. Plugs in on both ends cable shouldn't matter when u swap trans. Assuming the tires are what's reading wrong. Isn't it supposed to be a 14'
monsterjake30
Jul 8, 2013 08:09 AM
96Formula6spd
Sep 23, 2012 09:16 PM
effinsw33t
Jun 7, 2010 09:40 AM
lechuza05
Jul 22, 2007 10:22 AM
