95 Honda Accord 450cc Injector install.
Old Feb 12, 2016 | 02:00 PM
PunisherAccord's Avatar
Default 95 Honda Accord 450cc Injector install.
Can someone please help me verify this, so I got a 95 accord and it comes with a resistor box would that make DSM 450cc injectors plug and play or will I still have to play around with the wiring a bit to make them work? Need helpful input guys or some links.
My f22/f23 Turbo Build.
Old Feb 12, 2016 | 02:46 PM
Aradin's Avatar
Premium Member
Default Re: 95 Honda Accord 450cc Injector install.
They will be plug and play.
Old Feb 12, 2016 | 03:36 PM
Thanks Aradin, is the connector also the same I got the DSM pigtails I can easily wire them in but I just wanted to know for sure.
Old Feb 12, 2016 | 04:20 PM
Aradin's Avatar
Premium Member
Yes. I ran DSM 450s on my turbo Accord for a couple years. They drop right in, no problem.
Old Feb 13, 2016 | 05:18 PM
How much hp was it making with them?
Old Feb 13, 2016 | 05:58 PM
Aradin's Avatar
Premium Member
No idea. Maxxed them out on a stock block around 12-13psi on a 57 trim. Around 300whp if I had to guess.
Old Feb 13, 2016 | 10:55 PM
Nice man how much HP do these stock axles take? I'm shooting for the same numbers even though I'm capable of more. It's the axles that I think are most likely going to give out through time. Should I invest in let's say DSS axles?
Old Feb 14, 2016 | 10:56 AM
Aradin's Avatar
Premium Member
Depends on how you intend to abuse them. I made well over 400whp at one time and never had any axle issues but I never launched the car hard. It was mostly highway roll use and the stock Accord axles were just fine. If you're gonna constantly be launching the thing then it may be worth it to upgrade.
Old Feb 14, 2016 | 02:00 PM
Nice, well it'll be my first time boosting lol I feel like I pieced everything well using name brand ****. I was a bit worried about the axles not taking 300-350whp which is what I planned to make. it's pretty much 80% done I might get a block guard also just to support the cylinder walls a bit. Thanks for the input Aradin. ��������
batboyvaj
Jun 26, 2007 09:50 AM
boostedcb7
Mar 31, 2006 11:11 PM
Superorb
Feb 20, 2006 06:33 AM
accordexchange
Jan 2, 2003 05:49 AM
forcedaccord95
Aug 30, 2002 06:49 PM
