F23a1's TDC sensor
Old Feb 12, 2016 | 01:51 PM
Masterl1nk's Avatar
Default F23a1's TDC sensor
Hello guys,
I'm looking for some specs about TDC sensor on F23A engines. I'm going to Megasquirt a boosted Honda Accord. I'll use TDC sensor to sync the Megasquirt and fire injectors and coil.
Is the TDC sensor like other Hondas (4 tooth wheel)?
This is a D16 dizzy shaft with TDC wheel on left side:
Thank you!
Old Feb 14, 2016 | 04:59 AM
GhostAccord's Avatar
Default Re: F23a1's TDC sensor
Cylinder position sensor, the CYP is run off the camshaft and this sensor is located in the distributor. It is a 1 tooth wheel = 1 pulse / camshaft rotation 360°/engine cycle.
Crank position sensor, the CKP is run off the crankshaft and this sensor is located on the oil pump housing.
It is a 12 tooth wheel = 24 pulses / crankshaft rotation 720°/engine cycle.
Top dead center sensor, The TDC is also run off the crankshaft and also located on the oil pump housing.
It is a 2 tooth wheel = 4 pulses / crankshaft rotation 720°/engine cycle.
If you are using MegaSquirt you should look into using a two trigger wheel configuration. 1 cam wheel and 1 crank wheel. Use the cylinder position wheel and the crankshaft position wheel. If you look into it, this configuration should give you a much better resolution for a fully sequential fuel and ignition setup.
Old Feb 14, 2016 | 06:22 AM
Masterl1nk's Avatar
Thank you very much GhostAccord! I will condition the Megasquirt to sync this.
2009HondaAccord
Feb 18, 2018 06:41 PM
Greasemonkey
Oct 19, 2004 03:22 PM
