Can You Bypass the Crank Angle Sensor?
Old Feb 10, 2016 | 04:18 PM
stopltracr's Avatar
Default Can You Bypass the Crank Angle Sensor?
I've been getting the trouble code 4 ever since I installed a new distributor. I've tried 3 different ones with the same result. The car runs fine until you get over 3500rpm and then the check engine light comes on. The interesting thing is that when I reset the ECU to clear the code 4 one time I didn't follow the procedure I read. This time I took the negative cable off while I was eating dinner and then reconnected it and took off. Somehow this caused the idle to surge when warm but the code 4 never came back. I reset the ECU again a couple days later and the idle went back to normal but the code 4 came back.
Is it possible to bypass the crank angle using the cylinder one position sensor? Or is the ECU looking for these two inputs to be different?
Old Feb 10, 2016 | 05:08 PM
Sikocivic's Avatar
Default Re: Can You Bypass the Crank Angle Sensor?
I had the same problem with a DOHC ZC motor. Ended up replacing the ECU and that fixed it.
Old Feb 10, 2016 | 05:23 PM
~sp33~'s Avatar
EFB055
If you weren't having troubles before, and you've tried a few distributors, maybe check the harness side of the plug for a loose terminal. then check for continuity between the plug and the ECU. You might have a loose connection in there.
sierrakilo
Nov 14, 2006 07:56 AM
90crxdxb16
Sep 20, 2006 08:22 PM
KURUPTinc
Oct 28, 2005 10:17 AM
Cereal_Killer
Jan 23, 2002 04:58 AM
