Suspension & Brakes Theory, alignment, spring rates....
Cut into lower front control arm when removing bushings!
Old Feb 9, 2016 | 11:40 AM
skyviewLA01's Avatar
Default Cut into lower front control arm when removing bushings!
Hi,
I removed the old OEM bushings front lower control arms. I tried not to but I cut into the wishbone while cutting through the bushing sleeve. I cleaned and sanded down the surface to help smooth it out.
My question is if I insert polyurethane bushings will the cut/marks on the wishbone cause the bushing to tear and eventually destroy it? Some of the other marks were made by chisel.
OR
If I decide to use OEM style bushings (Hardrace) will the cut/marks between the wishbone and the outer sleeve make any difference? (Would it let moisture/water/dirt to get in between?
See photos below.
Thanks
Old Feb 9, 2016 | 05:53 PM
98civdx's Avatar
Master Detailer
Default Re: Cut into lower front control arm when removing bushings!
You'll be just fine.
I cut into my LCA's aswell, and i have no issues at all. I am among many who have done the same while putting bushings in.
Chalk it up to **** happens and move on.
Old Feb 25, 2016 | 11:51 AM
NVturbo's Avatar
O.G. triple O.G.
ditch that rusted LCA. There are plenty of used ones on eBay that look 100X better.
Old Feb 26, 2016 | 10:17 AM
skeeper_1968's Avatar
as I know, siberianbushing manufactures polyurethane bushings that may be used in these cases.
Old Feb 27, 2016 | 04:39 PM
oneheadlight's Avatar
one of the pictures if I'm looking at it correctly, shows a rust hole in the side of that LCA! Forget if the bushing will wear, I'd worry more about it cracking in half from the rust hole! lol.. time for some new LCA's!
Old Feb 28, 2016 | 05:51 PM
98civdx's Avatar
Master Detailer
All that lca needs is a some time in a blast cabinet and a fresh coat paint and some bushings.
beefystud
Suspension & Brakes
Mar 1, 2017 07:03 PM
oresama
Apr 15, 2012 07:54 PM
Furious Styles
Apr 26, 2011 02:16 PM
wlee112
28
Jun 25, 2007 08:08 PM
92LudeSR
Jan 6, 2006 02:30 PM
