1993 Civic del Sol S Integrated Control Unit Compatability
Hey everyone. I am having a hard time finding a replacement integrated control unit for my 1993 del Sol S. I was going to try and refurbish the old one, since often you can just touch up some old solder connections to get it to work again, but when I pulled it I found it to be in pretty bad shape. Lots of burns, etc. So I thought I'd buy another one and that's when things started to suck.
The original part is discontinued and hard to find on e-bay.
Honda Part # 38600-SR3-A13
Later ICU's are easier to find, but I'm not 100% sure if they're a direct swap or not. The 1996,97 ICU part number is #38600-S01-A11.
So the question is, can I use the later 38600-S01-A11 to replace my ICU in my 1993 del Sol S? Can I use an ICU from a similar model, like a Civic, instead?
Did you try to use or compare it with the Civic 92-95 ones.... going into a Junk car Yard... if you can get the electronic diagram for each 92-95 and 96-00 to make the conversion... good luck
Thanks for the replies. I was able to e-bay the following part 38600SR3A130M1 and it arrived as a complete fuse box and ICU. The ICUs were identical between the old and new even though the part numbers were different. I'm back in business. Still, since I never intend on getting rid of this car, I would have liked to use new (or refurbished as new) parts, but all things considered I'm very happy with the results
Shoulda got the newer one. Direct swap and would have given you a lights-on chime, increasing functionality. Oh well, live and learn!
skip122
Feb 15, 2007 12:07 PM
speedbreed
24
May 2, 2004 07:22 PM
hakemjmba
Feb 9, 2004 06:07 PM
bubbajim
29
May 12, 2003 04:47 AM
mugensport9
Apr 20, 2003 10:57 PM
