Caster question on ek
Old Feb 8, 2016 | 05:25 PM
POE's Avatar
POE
Default Caster question on ek
So I was looking at it seems like my caster was a little off, so I went and had an alignment. Found out the driver side has negative 0.3 caster. It doesn't pull or feel weird when driving should I replace anything or just keep an eye on it?
Old Feb 8, 2016 | 05:32 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Caster question on ek
Caster is non-adjustable. If it's that far off, something is bent. You need to get under there and figure out what's bent, and replace it.
Old Feb 8, 2016 | 05:35 PM
POE's Avatar
POE
So it could be a lower control arm? What else nothing with the naked eye looks bent so I'm not sure where to start replacing things , and don't want to waste time and money .
Old Feb 8, 2016 | 06:12 PM
NotARaCist's Avatar
So pull out a tape measure and start measuring. Upper A arm, control arm, or even just a failed bushing or ball joint could all cause it. You need to take the time to measure things and figure out what's wrong.
Old Feb 8, 2016 | 06:24 PM
POE's Avatar
POE
Gotcha thanks, any tips or links on measuring all the different suspension pieces to find the bend or bad ball joint / bushing ?
Old Feb 8, 2016 | 06:37 PM
NotARaCist's Avatar
It's all mirrored. Your right side looks fine, so just compare right to left. I feel like you're overthinking this whole process. Also, get your toe fixed before you chew through your tires.
Old Feb 8, 2016 | 06:54 PM
POE's Avatar
POE
Lol thanks. Yeah I'm putting new coilovers on so I will after this fix and then I will. Thanks for your help. I'll follow up after this weekend
mikej94civex
Dec 31, 2009 01:39 PM
gshatch
Jul 27, 2008 09:48 AM
divingcorners
Suspension & Brakes
Aug 17, 2006 10:00 AM
