Honda CR-V & Element 2WD & 4WD Element & CR-V
Weird intermittent almost white noise at idle
Old Feb 7, 2016 | 10:35 AM
jeckel7234's Avatar
Default Weird intermittent almost white noise at idle
Hi all,
I have an 06' CR-V AWD 2.4L with just over 100k miles. In the last week it has been making a almost light grinding noise cycling off and on every second. I've replaced the serpentine belt & tensioner pulley with no avail. Can anyone give me any further perspective on this noise, ill link an audio file of the noise.
https://drive.google.com/file/d/0Bw4...ew?usp=sharing
Old Feb 7, 2016 | 12:45 PM
UK-Kev's Avatar
Default Re: Weird intermittent almost white noise at idle
Presuming that you have no problems with your tensioner pulley and you have the correct tension on the drive belt, does the noise go if you depress the clutch? Also you might drop your alternator belt to eliminate any problems with the alternator bearings’.
Kev
civic_driver
21
Jun 7, 2009 05:01 PM
TehGhett0P1mp
Aug 7, 2008 06:13 PM
shadohconspiracy
15
Oct 11, 2007 03:48 PM
GSRpoweredSI
Jun 20, 2007 01:13 PM
droc327
Apr 26, 2005 12:54 PM
