eg gsr swap - Fuel pump not priming.
Old Feb 4, 2016 | 11:40 AM
redbull99's Avatar
Default eg gsr swap - Fuel pump not priming.
Replaced the fuel pump a month ago ran fine, now the fuel pump is not priming. I checked fuse 31 and 24 they are good, i also replaced the relay , it didnt fix the problem. when i jumped 1 and 7 on main relay fuel pump primed, when i jumped 1 and 5 it didnt. eg gsr swap
Old Feb 4, 2016 | 12:57 PM
Former User's Avatar
Default Re: eg gsr swap - Fuel pump not priming.
Try jumping 5 to 7 with key in ON(II).
Old Feb 4, 2016 | 05:48 PM
redbull99's Avatar
i did it already fuel pump not priming , it primes with 1 and 7.
I opened my ecu and theres a black thing Q03 that is burnt split in half . i dont know what its called, would that be the problem?
its spllit in half<br/>
Old Feb 4, 2016 | 05:56 PM
If 5 to 7 doesn't prime, then there is a non-ECU problem. Voltage test fuse 24.
Old Feb 4, 2016 | 05:59 PM
redbull99's Avatar
can you explain what 1,7 and 1,5 are ? also this happen right after i cut injector #1 connector to wire in new connector.
Old Feb 4, 2016 | 06:01 PM
Jumping pin 1 to 7 or pin 5 to 7 in the unplugged main relay connector bypasses the ECU by sending voltage directly to the fuel pump.
Properly test fuse 24.
Old Feb 4, 2016 | 06:10 PM
redbull99's Avatar
thanks, like i said 1 and 7 fuel pump prime, 1,5 it doesnt thats why i asked what is 1,5 . ill check the voltage on fuse 24. what is it suppose to be?
Old Feb 4, 2016 | 06:11 PM
Pin 1 to 5 is a completely meaningless test. The proper test is 5 to 7.
Old Feb 4, 2016 | 06:23 PM
redbull99's Avatar
I just noticed this , could this be the problem ? im going to go try 5 and 7 right now
Old Feb 4, 2016 | 06:37 PM
redbull99's Avatar
ok fuel pump primes at 5,7 . i turned the car to on position and then used my digital multi meter put the tips on the metal tabs on fuse 24 (15a) and got 0v reading . thats without the ecu hooked up
Old Feb 5, 2016 | 09:48 AM
redbull99's Avatar
bump, how do i fix the no power to fuse 24 ?
Old Feb 5, 2016 | 12:31 PM
redbull99's Avatar
one of the injectors wires was pinned under the fuel rail bolt and it kept blowing fuse 31, problem solved car runs, and that black burned transistor q31 is for evap solenoid dont really need it ecu runs good as well.
MU3RT3
Feb 23, 2016 06:09 AM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
gsrt nick
Oct 23, 2006 03:29 PM
