won't start after change oil pan GSKT
Old Feb 3, 2016 | 01:12 PM
carlos8's Avatar
Default won't start after change oil pan GSKT
like the tittle say. Last week I rebuilt my bottom end for cheap I reuse the oil pan gasket and start leak. Yesterday I remove the negative battery terminal, remove the downpipe from the V-band and changed the gasket.
When I went to start it, crank but not start. Check light comes with the switch and turn off. I find no spark, switch to my spare dist. and nothing, check for 12v in the dist. plug on both sides of the BLK/YEL wire and is fine.
Any suggestion or ideas are welcome.
Old Feb 3, 2016 | 03:09 PM
carlos8's Avatar
Default Re: won't start after change oil pan GSKT
civic ex 97
p28 crome-pro
LS/VTEC
fuel pump primes
new wires and plugs NGK (from last week)
Old Feb 3, 2016 | 03:50 PM
Former User's Avatar
Battery voltage reaches coil and ICM?
Old Feb 3, 2016 | 04:23 PM
carlos8's Avatar
Not made that test yet, tomorrow at first light I will and let you know.
Thanks.
Old Feb 4, 2016 | 06:05 AM
carlos8's Avatar
Performed the test: 12.4v at coil and ignitor. Put the other distributor and the same readings.
What other part can cause this situation?
Old Feb 4, 2016 | 12:22 PM
carlos8's Avatar
Fixed!!! Open A20 at ECU plug.
Old Feb 4, 2016 | 01:32 PM
BuddhistPriest87
Honda Civic (2006 - 2015)
Feb 10, 2012 02:40 PM
slacker6
Aug 31, 2010 01:33 PM
debogsr
Mar 25, 2008 10:23 PM
r1ch1e
21
Oct 20, 2007 07:10 AM
Hiii Im TYLER
Apr 10, 2007 12:34 PM
