Transmission & Drivetrain Gearboxes, Differentials, Clutches
How to bleed hydraulic clutch by yourself
Old Feb 2, 2016 | 12:30 PM
oldschoolmaster's Avatar
Default How to bleed hydraulic clutch by yourself
I hope this helps someone out there from asking again
Step 1 open bleeder screw one turn or so
Step 2 use a oiler from old school hardware store attach a vacuum tube hose then fill canister with brake clutch fluid
step 3 pump up squirter to bleed air then attach hose to bleeder
step 4 pump up till u see all the bubbles come up reservoir
( doesn't overflow if you good )
Step 5 while pumping hand tighten bleeder
step 6 torque bleeder
done in minutes by your self
attached is pic of my oil pump and hose
CAUTION DO AT OWN RISK IF YOU DONT OPEN BLEEDER AND TRY IT WILL SPRAY BRAKE FLUID Possible IN EYES
5.99 at hardware store
sing
May 20, 2013 05:28 AM
niceprelude
Jun 2, 2011 02:50 PM
urtz
Nov 27, 2006 05:37 PM
Shotman
Jan 12, 2005 05:48 PM
sparq
12
May 1, 2003 11:18 AM
