94 civic ex d16z6 code 4
Old Feb 1, 2016 | 05:45 PM
Mtjohns71's Avatar
Default 94 civic ex d16z6 code 4
Hey there, my ex coupe is throwing off a code 4 and after research its the crank position sensor which is inconveniently located in the dizzy. To avoid throwing money at the problem I'm trying to troubleshoot as much as humanly possible. I've tested continuity between the ECU plug and dizzy plug for both wires and they're fine. I also saw on a diagram on another site that said I should get 350-700 ohms on something and I'm getting 0.4 ohms while set to 200 ohms on the wires themselves. Should I be testing the resistance within the dizzy itself on the male side of the connection to get the 350-700 or what? This is my first civic and first day with a multimeter. Consider me completely stupid with your responses please.
Old Feb 1, 2016 | 05:52 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 94 civic ex d16z6 code 4
The FSM will tell you exactly what to do.
Attachment 516028
Attachment 516029
Old Feb 1, 2016 | 06:15 PM
Mtjohns71's Avatar
That's the diagram I used to get this far. I'm getting 0.4 ohms between b and b15 also 0.4 between f and b16. When I test the male side of the dizzy connector for the crank it reads open circuit. I can't figure out where to get the 350-700 unless the 0.4 would be 4xx at a smaller test setting (200 is as low as mine will set)
Old Feb 1, 2016 | 06:29 PM
NotARaCist's Avatar
What are all of the resistance setting options on your multimeter? Since you're testing for 350-700, your range should be as low as possible while still covering up to 700 ohms.
Old Feb 1, 2016 | 06:37 PM
Mtjohns71's Avatar
200, 2000, 20k, 200k, 2000k. 200 is the only setting that picks up anything, so should I view that as not getting the 350-700 or do you reckon I'm not testing the correct area, I read it as test the wires from dizzy connector to ecu connector for resistance so I did, I also tested the dizzy using the 2 male plugs for the crank as if that made a circuit (read open circuit) and test the 2 females going to the ECU as if it made a circuit and it also read open
93egtypeR
24
Aug 5, 2010 01:04 PM
crxpwr1
18
Apr 3, 2007 11:21 AM
wu tang
16
Apr 6, 2003 07:18 PM
