door handles?
Old Feb 1, 2016 | 07:15 AM
Jaymzbo32's Avatar
Default door handles?
so I looked in the FAQ's but can not seem to find this covered, i need to replace the drivers side door handle on my 93 Del Sol. i do have a general knowledge of doing this kinda stuff so I could get by but still better to ask than run in blind. How would i go about changing the door handle? I'm assuming i have to remove the inner door panel no matter what but the one that's on there is busted up so i don't know about the screwing and mounting. and before anyone makes a snide remark i know i should go out there and grab one of the replacements and look it over to see if that will tell me anything
Old Feb 1, 2016 | 07:41 AM
Jaymzbo32's Avatar
Default Re: door handles?
and sorry i should be more specific. It's the exterior handle that I have to replace
Old Feb 1, 2016 | 07:54 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Here you go; (All I did was Google "Del sol exterior door handle replacement")
Door Handle Repair (92-95 Civic & 93-97 del Sol) - HondaCivicForum.com
Get yourself a copy of the factory service manual. There are free downloads online. If you're going to work on your car you'll need it.
Just google "Del sol factory service manual". Literally, copy and paste that into google.
eH.
Old Feb 1, 2016 | 07:58 AM
24TEN's Avatar
PHANTOM MENACE
Search for a Factory Service Manual aka FSM.
You can also look at any number of online parts dealers and use their diagrams for reference.
You'd be right to assume the door panel will need to be removed but if it's "busted up" as you have stated then you're going to have to figure it out or post pictures of what's busted up. How can anyone help you if you only provide a vague explanation of what's wrong? I'd start by removing all screws and bolts/nuts you can see and then post back.
EDIT: "eH" beat me to it.
Old Feb 1, 2016 | 01:28 PM
hondur's Avatar
Dur Da Dur
5 Year Member
Be careful pulling the door panel out, you need to push against it with a lot of force near the interior door handle or you'l break that while trying to pull it out.
Old Feb 1, 2016 | 02:16 PM
Jaymzbo32's Avatar
Okay thanks for the tip
Old Feb 1, 2016 | 02:18 PM
Jaymzbo32's Avatar
No the interior door panel is not busted up it's the exterior door handle that's busted up
Old Dec 21, 2020 | 10:53 AM
DCdelsol's Avatar
Yes, I realize this is a 4-year old thread.
I need to replace driver’s door handle assembly on my 1997 del sol. I found a closed thread which reported that the OEM interior assembly for the 93-95 will fit my 97, only difference being grey vs. black. Hopefully, that is the case. What about the exterior assembly? Will 93-95 OEM exterior assembly fit my 97?
Old Dec 23, 2020 | 02:22 PM
egsleepercivic's Avatar
rockauto shows they both use the same aftermarket replacements
I believe they are the same
https://www.rockauto.com/en/catalog/...or+handle,1024
suzieffbaby
Mar 29, 2011 04:51 PM
PinoyDelSol
Nov 10, 2007 12:11 AM
