Eg si wiring issue
Old Jan 31, 2016 | 06:59 PM
ehwreckuno's Avatar
Default Eg si wiring issue
I have 93 eg si
I bought it as a shell it had no engine harness and no interior dash harness
So I went to the junk yard and picked up and interior dash harness off and ej1 ex 5 speed .
Then I bought a b20v engine with a ls trans, engine had an obd1 harness. I'm having issues with the car not reving up past 4K
Just recently got the distributor rebuilt
I'm using a chipped p28 ecu
I don't know what engine harness I have on the swap
So my question now is should I get the ej1 engine harness or should I mess with the engine I have on it now ?
Old Jan 31, 2016 | 07:03 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Eg si wiring issue
You should pull any CEL codes and post them.
Old Jan 31, 2016 | 07:08 PM
ehwreckuno's Avatar
Only Cel code i get is a code 4
Old Jan 31, 2016 | 07:46 PM
NotARaCist's Avatar
Which is the CKP sensor, which will put the ECU into limp mode, which will stop it from going past 4000 RPM. If you don't have a voltmeter, go buy one, then follow this flowchart.
Old Feb 1, 2016 | 07:24 AM
Tjw149's Avatar
Socket and chip the ECU to bypass the Crank Sensor.
Old Feb 1, 2016 | 11:19 AM
NotARaCist's Avatar
...Or fix the issue properly.
Rheg6
Engine Management and Tuning
Mar 11, 2010 11:20 AM
nycpatron
Feb 25, 2010 07:53 PM
Jdmdctek
Jun 11, 2007 07:55 AM
ABK
May 11, 2004 03:47 PM
lazy bum shaughn
Nov 27, 2003 08:29 PM
