60 psi on the fourth cylinder d16y7
Old Jan 31, 2016 | 03:47 PM
freshgear's Avatar
Default 60 psi on the fourth cylinder d16y7
So guys,
Just brought the head to the machine shop valves clean out and resurfaced. I had a blown gasket the compression came in the radiator system.
So a placed the new headgasket when i accendenly dropped some carbo cleaner on the headgasket.
The carbo cleaner took the seal(black coating) out of the gasket on some area. I tried to wipe it off. But the coating went off.
I diceded to put some shallak (abro eagel head)
So i put in all toughter
But now the engine has a rough idle
I did a compression test and the first second en third gave me 150psi the fourth gave me 60psi
Whats the problem??? Did the headgasket failed???
Old Jan 31, 2016 | 04:00 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 60 psi on the fourth cylinder d16y7
Probably. Do a pressure test to figure out where the pressure is going. See this post in my build thread for a how-to.
Xist
Jun 29, 2018 05:08 AM
rxbahamut
Oct 17, 2011 06:33 PM
Tomsecks
Nov 12, 2005 11:57 AM
SNsLude
Sep 8, 2005 03:18 PM
MLogan
May 22, 2003 01:09 PM
