B series head gasket
Old Jan 31, 2016 | 02:17 AM
J.Berta's Avatar
Default B series head gasket
Who makes thicker head gaskets besides Cometic ?
Old Jan 31, 2016 | 04:35 AM
blackeg's Avatar
Default Re: B series head gasket
how much thicker are you looking for? i think the je proseal gaskets are .033"a bit thicker than oem. i guess you could always disassemble a cometic and take out the middle layer and use it with oem top and bottom layer so long as the bores match.....
Old Jan 31, 2016 | 08:05 AM
J.Berta's Avatar
My gsr head has .022" shaved off. Was just trying to get it back as close as I can. Head/ITR cams will be used on a ITR bottomend end. Just trying to make sure I have sufficient piston to head and valve to piston clearance.
Cometic gaskets crimp ring is definitely smaller than oem crimp ring. Also a reason to source another company.
Old Feb 2, 2016 | 11:16 AM
J.Berta's Avatar
Have you ever personally done that ?
Old Mar 7, 2016 | 01:30 PM
dewey_civic's Avatar
i had my head and block decked. The Cometic is the way to go.
Ryan15
Sep 15, 2006 09:58 PM
YoungMoneySi
Jan 23, 2006 07:26 PM
xyzalvarez
Dec 1, 2005 11:13 PM
