Engine Block Leaking Coolant
Old Jan 30, 2016 | 11:47 AM
MrRedLogan's Avatar
Default Engine Block Leaking Coolant
Hey you guys. Coming to you to see if you can give me a hand. Recently my 2002 Honda Accord SE started to over heat. She has 209,xxx on her and im not ready for her to die yet. I have posted two images below to show where i think the leak is coming from. Notice how I say "I think". If anyone one can help me it would be a great help! Also if you could help identify what that plug is.
Please and Thanks,
MrRedLogan
Old Jan 31, 2016 | 02:53 AM
hondamark35's Avatar
Default Re: Engine Block Leaking Coolant
the plug (hole) you've indicated with the arrow is part of the oil pump so coolant would not be coming from there. just above that however is the weep hole for the water pump. when it begins leaking it's time to replace the pump.
the good news, the pumps are cheap and will buy you another 100k miles+
the not so good news, it's a weekends worth of work to get the timing belt off and out of the way and you should really replace the belt and all seals as well.
the best thing to do is a timing belt kit:
timing belt
balancer belt
cam seal
crank seal
left (front) balancer seal
right (rear) balancer seal
water pump
thermostat
accessory belts
valve cover gasket set
and check the coolant hoses. replace if they don't look new, are swollen, leaking or kind of "cruch" when you give a light squeeze.
Yao Saechao
Mar 26, 2018 01:25 AM
accord1986
Jan 27, 2013 03:01 AM
Duzercivic97
12
Oct 6, 2012 06:48 PM
tjowers
Dec 14, 2009 01:01 PM
acteg94
Feb 10, 2004 05:44 PM
