POSSIBLE DISCUSSION:idle adjustment
Old Jan 29, 2016 | 11:41 AM
tony_2018's Avatar
Fish Twig
Default POSSIBLE DISCUSSION:idle adjustment
Ok,
2000 HONDA CIVIC D15Z7, DUAL STAGE VTECT, 3 STAGE VTECT (WHATEVER THE **** ITS CALLED)
So the FSM states that the idle MUST be set at 450 +/-50 rpms. After plugging back in the IACV plug and resetting the ecu the Idle should be at 750 +/-50 rpms. I feel thats is too low.
From 1000rpm to the 2nd line nearest to the 0 its right inbetween. The 2nd line from the zero indicates 500rpm. Am I thinking about this the wrong way?
Old Jan 29, 2016 | 11:57 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: POSSIBLE DISCUSSION:idle adjustment
Slightly wrong, yes. The OEM cluster is horribly inaccurate to begin with - you should use an external tach to set idle. That being said, below the 1k RPM mark, all bets are completely off. What makes you think 750 is low, though? It's what the FSM states for D and B motors from 92-00.
Old Jan 29, 2016 | 12:32 PM
Former User's Avatar
Yep, use an accurate tach to set the 450 rpm base idle. Then go from there.
Old Jan 29, 2016 | 12:37 PM
tony_2018's Avatar
Fish Twig
So where does 450 ly on the oem gauge cluster? I've been told, pretty old discussion long ago on T-I site, that the 2nd line from the 0 means 500rpm.
Old Jan 29, 2016 | 12:58 PM
NotARaCist's Avatar
It doesn't. Come on tony, you're smart enough to get this the first time around man.
Old Jan 29, 2016 | 01:03 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
And the book says 450 + 50 or -50....
So shoot for right at that 500rpm mark...
Old Jan 29, 2016 | 03:15 PM
tony_2018's Avatar
Fish Twig
**** it, I'll wing it.
Old Jan 29, 2016 | 05:39 PM
hondur's Avatar
Dur Da Dur
5 Year Member
You don't have a nice snapon timing light that gives a digital rpm read out? That sucks
Old Jan 29, 2016 | 06:10 PM
Ameedoe's Avatar
Those are expensive.
450 is really low idle isn't it?
Old Jan 29, 2016 | 06:39 PM
NotARaCist's Avatar
450 is base, uncontrolled idle. When you plug in the IACV, it'll go back up to 750.
Old Jan 29, 2016 | 07:40 PM
BigECivic's Avatar
Why are you resetting the idle+ what's the car doing? Did u change or adjust something that made your idle seem off?
Old Jan 29, 2016 | 10:41 PM
tony_2018's Avatar
Fish Twig
replacing iacv, CEL, i checked everything (thats how us TECH guys do things). OEM or bust.
Anyways, I'll give it a go in the AM. Busting my *** at work.
Old Jan 30, 2016 | 07:55 AM
http://www.amazon.com/s/ref=nb_sb_no...+digital++tach
Old Jan 30, 2016 | 01:34 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I meant to grab one of these from Princess Auto when they had it on for 19.99 CAD. With the exchange rate, 20 bucks CAD is a pretty good deal right now. To bad I got side tracked with everything going on right now, will have to wait for the next opportunity.
Old Jan 30, 2016 | 02:11 PM
tony_2018's Avatar
Fish Twig
Is this all I need, or is there some sort of tape I also need to purchase?
K, I youtubed it. Its coming in Tuesday.
Old Jan 30, 2016 | 02:13 PM
Omar Chavez's Avatar
Has any one here done a y7 block with z6 vtec head on a 98 honda civic ?
Old Jan 30, 2016 | 02:53 PM
Don't thread jack.
Old Jan 30, 2016 | 02:54 PM
It should come with some reflective tape.
Old Feb 1, 2016 | 07:20 PM
tony_2018's Avatar
Fish Twig
Any suggestions on where the tape should go? Crank doesn't look like theres enough room for a 1/2 inch strip.
Old Feb 1, 2016 | 09:53 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If you have power steering you can take the belt off temporarily for the process.
I would clean the spot on the belt grooves you want the tape with some brake clean first and let evaporate so the tape has the best chances of sticking to the grooves.
Old Feb 2, 2016 | 02:27 AM
tony_2018's Avatar
Fish Twig
Damn, didn't think about that. I assume the idle needs to be set with all the utility belts on to be more accurate.
Old Feb 2, 2016 | 11:31 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I sort of doubt that being they say +/- 50 RPM.
I doubt the power steering belt when not "turning" the wheel is going to load the engine more than 50 rpm.
I think the real load of the power steering pump is only when you are cranking the steering wheel one way or the other.
Old Feb 2, 2016 | 01:20 PM
tony_2018's Avatar
Fish Twig
I'm hoping the tape will stick on there long enough before getting flung off. I got time now, amazon prime ftmfw.
Old Feb 2, 2016 | 06:38 PM
NotARaCist's Avatar
Clean the contact surface off with rubbing alcohol, and the tape will stay on.
Old Feb 2, 2016 | 10:13 PM
tony_2018's Avatar
Fish Twig
Well, the surface is just where the belt meets the crank, where the splines are.
