Converting an EK4 (B16A2) back to a D16 swap Help !
Hey Whats up guys,
Just had a few questions regarding swapping an obd-2 d-series back into my EK4 that originally had a b16a2. Just would like to know the things i would need in order to complete the swap successfully. I understand i need the engine, transmission, wiring harness, axles, ecu, and shift linkage. However, I counted my b-series axle splines and there 26 teeth, also would i be able to use my b-series shift linkage or would i need to get a shift linkage from a civic ? if so, would a civic sedan linkage work ? any info would be greatly appreciated.
-Thank you.
-Thank you.
Since the mods seem to prefer it this way...
B series axles are different then D series axles. Google the terms and look at the images. Not even close.
Same with B and D series shift linkages. D series shift liankges are for D series transmissions.
If you have a concern or question about what part fits what look at an online Honda parts store and compare part numbers.
Examples include Honda Parts OEM 30% Off | No Tax!! Outside California | Honda Dealer Parts or Majestic Honda - The Internet's #1 Honda Automotive Parts Store
There is also a FAQ sticky at the top of this forum, in a dark gray color, that will link to many resources with respect to engine swapping.
eH.
eH.
1. No
2. NO
3. No
You should look up guides on how to swap a b-series into an EK, the requirements. From there it should give you an idea of what you can't reuse. Dat symple
2. NO
3. No
eH.
I know he's reverting back to D, If you look at any guide that tells you how to swap a B it usually list the parts needed. From there you would get an idea of whats not going to be re-used from a D. Reverse that and you have your answer.
-HONDA-
Mar 28, 2007 04:08 AM
