Honda CR-V & Element 2WD & 4WD Element & CR-V
Tread depth on CR-V AWD
Old Jan 28, 2016 | 11:02 AM
Atauto's Avatar
Default Tread depth on CR-V AWD
In the right rear tire a screw managed to puncture the tire in the sidewall area. So I'm looking to replace just that one tire because all the other tires have a decent amount left to drive on.
My question is, is it true that on AWD all the tires have to be exactly the same tread depth? Every salesperson I talked to has said this to justify replacing all four tires.
Old Jan 28, 2016 | 08:47 PM
EJ8_Man's Avatar
Default Re: Tread depth on CR-V AWD
The system is sensitive to tires rotating at different rates from one another. This typically happens when one or more tires are slipping.
A person could simulate this by installing a wheel with a radius different than the others. The question here is are your tires the same diameter (or close enough) such that your 4wd system does not think your tires are slipping.
I'm going to guess that it will be fine. But if you want a real answer you'd have to do a bit of measuring and then apply some math. I doubt anyone will know the magic ratios which are mechanically regulated in the rear diff that dictate when the 4wd engages.
If you swap in a new tire and you feel the awd kicking in when it shouldnt then yes you need to replace the rest. But I do think a good engineer would have allowed tolerance for differences in tire pressure, and during turning.
In short few will be qualified to truly answer this. Near univeral ignorance is a salesman's dream. You need an answer from the guy at Honda who designed this. Not a tire salesman.
Old Jan 29, 2016 | 10:23 AM
Aggression's Avatar
Take everything I say with a grain of salt. I do not know much about the rear ends in this car, or much of anything really. I based all of my math on things I have read online.
The CR-V rear end looks for a 3% difference, fronts rotating faster than the rear, before engaging the rear differential. The OEM specs for a CR-V tire is 205/70 R15, which would give us a diameter of ~26.3". 26.3" x 0.97 = ~25.5". Meaning the front tires would have to have over 0.400" tread wear. General all purpose tires have 10/32 - 11/32 (0.3125" - 0.34375") of usable tread before needing to be replaced. This would mean you'd be riding on the steel cords in the tire before this ever became a factor.
Old Jan 29, 2016 | 10:25 AM
EJ8_Man's Avatar
The CR-V rear end looks for a 3% difference, fronts rotating faster than the rear, before engaging the rear differential. The OEM specs for a CR-V tire is 205/70 R15, which would give us a diameter of ~26.3". 26.3" x .97 = ~25.5". Meaning the front tires would have to have over .400" tread wear. General all purpose tires have 10/32 or 11/32 of usable tread before needing to be replaced. This would mean you'd be riding on the steel cords in the tire before this ever became a factor.
works for me
Old Feb 1, 2016 | 07:41 PM
Atauto's Avatar
Thanks for the response EJ8 and Aggression Makes sense to me
Old Feb 4, 2021 | 09:11 AM
Cowboy1611's Avatar
5 Year Member
This is an old post, but my question is the same....Atauto was.
so are there 2 concerns , 1) from front to rear axles and/or
2) difference between Right / Left side tire per axle ?
In other words , on the rear if one tire is 3/32 less than the other side, is that an issue>
Old Feb 4, 2021 | 09:18 AM
Davey7847's Avatar
It wont make a difference .
First , the differential will soak up the minor size difference across the axle . And average it out; 3/32 will be split to 1.5/32 total diff across the axle.
Second, Honda Engineers thought of this scenario in designing the system already and the rear differential has two pumps in it that operate the all-wheel-drive system. The first pump is driven by the drive shaft and the second pump is driven by the differential .The two pumps different size by 2.5% and that is to make up for a difference in Tire circumference from the front and the rear, accounting for tire wear.
see the pic below for Honda's own system description.
Old Feb 4, 2021 | 11:33 AM
uDraft's Avatar
I just lost a single tire. I'm going to buy just one. It will either ride nice or not, if not, I'll buy the 2nd tire. Be warned about salesman of all feather, some may even tell you they can't legally install 1 new tire or/if/whatever. This will give you chance to find a good honest tire shop. Long shot would be to find a used tire of the same spec and mileage.
Old Feb 4, 2021 | 11:41 AM
Cowboy1611's Avatar
5 Year Member
Thanks Davey7847
I will start out with the new one on the rear axle..... at some point I'll have to rotate them up front, any issue there ?
Old Feb 4, 2021 | 12:30 PM
Davey7847's Avatar
Originally Posted by Cowboy1611
Thanks Davey7847
No . Should be fine . I just recently bought a CRV with a set of snow tires on it that the previous owner obviously never rotated. I measured the circumference on the two tires and they're different by almost 1/4 of an inch. I've experimented with the tires front back and side to side just to see what effect it would have and the effect was 0 so you should be okay. As I said Honda Engineers anticipated this would happen as long as the tires are the same aspect ratio/size you shouldn't run into any problems with some normal tire wear
PatrickGSR94
Mar 11, 2013 05:12 AM
Tyte-S
Dec 1, 2010 07:37 PM
Squad1
Honda Motorcycles
28
May 20, 2007 08:37 PM
00siandrew
Oct 1, 2006 10:26 AM
teg969
Mar 21, 2006 01:19 PM
