Fuel pump doesnt prime.
Old Jan 26, 2016 | 06:55 PM
NovaRex's Avatar
Default Fuel pump doesnt prime.
While my car was running I accidently hit my kill switch to my fuel pump and it doesn't start anymore , tried a million times on and off and still nothing ,i don't hear it prime now , removed switch checked out all wires /fuses, relays all good, so I decided to replace:
. main relay
. fuel pump
. fuel tank/ straps /hoses
. fuel sending unit
And it still doesn't prime I got another si ecu and pluged it into my car and still nothing, used dmm on the 4 pin connector near sending unit flucuates from 3 to 6 volts while key on, I am so lost at this point. Any advise?
Old Jan 26, 2016 | 07:38 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Fuel pump doesnt prime.
Trace the wiring back and see where the power stops. Check the FSM I believe there's a diagnostic procedure specifically for this.
Old Jan 27, 2016 | 06:59 AM
brixcivic's Avatar
had same problem. went crazy. turned out to be fuse #14 under the dash. check all your fuses. good luck
EusebioSam19
Nov 22, 2010 09:21 PM
jianwa
Jul 31, 2010 02:03 PM
cleanazcoupe
Audio / Security / Video
Mar 12, 2009 09:45 AM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
