Transmission & Drivetrain Gearboxes, Differentials, Clutches
how to repair 3rd gear grind
Old Jan 23, 2016 | 02:35 PM
ls-t eg's Avatar
Default how to repair 3rd gear grind
Hello everyone, I have a hydro ls trans with a 3rd gear grind. Was planning on replacing syncro to fix it but torebit apart an the syncr is actually in good shape but the gear itself is what's causing the bite. I can get a new slider but can't buy a new gear for ls. Only available for gsr b16 or type r. I've checked Acura synchrotech and gear speed and can find a replacement. So my question is does anybody have experience repairing the gear itself? I remember reading a while back someone had sanded the rough edges and kind of re shaped it to work but I was looking for a refresher or some info on this. I dont want to shoot in the dark by trying it myself just off memory and causing more damage. Thank you in advance for any help.
Old Jan 23, 2016 | 02:53 PM
oldschoolmaster's Avatar
Default Re: how to repair 3rd gear grind
I use a hand file and wire brush
Old Jan 24, 2016 | 12:52 AM
ls-t eg's Avatar
Do you have any pictures? Is this process pretty cut and dry on how to do it or is it a finesse of magic hands to get it done?
Old Jan 24, 2016 | 03:11 AM
If u never learned it by old master of it like I did then it might take a while
no pics and won't post any good luck
My best advice is to take your time
Old Jan 25, 2016 | 10:29 PM
slowcivic2k's Avatar
In situations like this, you need to post pictures of the parts you plan on reworking. The procedure itself is fairly straightforward, but without gauging the severity of the wear, you may be wasting hours and hours of time, for nothing in the end.
Post pics of the gear, the synchronizer, the synchro and the gear installed on one another, and the hub and slider as well.
Old Jan 27, 2016 | 08:25 PM
yungmulacrx's Avatar
Yes post pictures up.. but usually you can just replace the engagement ring and a new slider but I would throw a new synchro in it at the same time if it was me.. Synchro Gear 3-4 B16 GSR ITR H22
Old Jan 28, 2016 | 12:02 PM
David @ Synchrotech's Avatar
Unfortunately the synchro gear engagement teeth can only be replaced separately on the B18C/B16A GSR/ITR. The LS trans has a one piece 3rd gear and the engagement teeth are part of the gear.
Old Jan 28, 2016 | 12:21 PM
I don't know how I missed the ls trans part..
Rickvanuden
Jun 8, 2017 09:00 AM
IN VTEC
Jul 29, 2006 05:38 PM
bustedasscivic
Nov 16, 2003 09:59 AM
not so civic
Jun 18, 2003 09:07 PM
