SRS Light Won't Turn Off
Old Jan 23, 2016 | 09:55 AM
GearHeadDriver's Avatar
Icon5 SRS Light Won't Turn Off
I have a 95 Honda Civic VX Hatchback. The car is stock and has the original airbags. I had the dash removed and reinstalled into the car recently. I also had only the steering wheel replaced with another OEM one. I kept the original airbag with the replacement wheel. Since the dash has been put back together, the SRS light will not go off. I had Honda do a jump to the connector and according to them the light comes back on after they started the car. The light does not blink nor does the car make any sound. The light is just lit.
The light wasn't ever on before I had the dash pulled.
Does anyone have a clue on what I could do to fix this?
A few people suggested I buy the clock spring, and start with that. I was thinking about going back to Honda because my local shops just don't have a clue and their prices aren't great compared to my Honda dealer.
Any info would be greatly appreciated. Thanks!
Old Jan 24, 2016 | 02:09 PM
v4lu3s's Avatar
RTFM
Default Re: SRS Light Won't Turn Off
Check the srs codes.
Old Jan 26, 2016 | 10:15 AM
I just got back from Honda. They were very candid and honest with what they were suggestion.
First off, the Reel Assembly (also known as the clock spring) is bad. She said it could be a pinched wire or even a sensor isn't plugged in fully, or just broken. She suggested I go out and buy an OEM Honda replacement part (even if it's not from them) to see if that fixes the problem. The car was also throwing also codes such as: the SRS unit and airbag. She indicated to me that the subsequent codes could be from the initial problem (clock spring).
For what it's worth, my horn buttons do work.
So, my question to you all is, should I buy a used clock spring and risk having it go bad on me, or go new?
Old Jan 27, 2016 | 03:57 AM
Bump. Does anyone have a suggestion?
Old Jan 27, 2016 | 10:55 AM
Former User's Avatar
Post the actual codes.
Old Jan 27, 2016 | 10:57 AM
Shoot, all I have is the parts invoice from the service department. They were written up based on each code that was triggered.
Old Jan 27, 2016 | 10:58 AM
You don't need the service department. Just jump the service connector and post a video of the SRS light blinking the codes.
Old Jan 27, 2016 | 11:00 AM
I will do that now. Thanks!
Old Jan 27, 2016 | 11:13 AM
Here is a video of the codes.
https://www.dropbox.com/s/ot6757g5a3...08.41.mov?dl=0
Old Jan 28, 2016 | 02:42 PM
Bump
Old Jan 28, 2016 | 02:57 PM
SRS codes 1-1 and 9-2.
1-1: Check for an open in the SRS wires of the cable reel.
9-2: Check whether dash fuse 25 is blown.
Old Jan 29, 2016 | 03:58 PM
Thank you RonJ,
I will report back on that as soon as I get my car returned to me. It's having some unrelated work done. I expect it to be back in my possession approximately in a week.
Old Feb 16, 2016 | 02:17 PM
The dash fuse is not blown. The clock spring has been checked multiple times. However, it was not metered to see if voltage is running through it.
What's next?
Old Feb 19, 2016 | 01:35 PM
Bump. Does anyone have another solution for this SRS light problem?
Old Feb 20, 2016 | 05:25 PM
I ordered a used clock spring. I'm going to have that replaced next week to see if it solves anything.
Old Mar 7, 2016 | 06:57 AM
SRS light is now OFF. I had my friend replace the clock spring with one from an EX (or similar) and the light went off after he did the reset on the system. The only difficulty was that the clock spring was not a VX model which meant the yellow plug for the horn on the clock spring did not plug into the steering wheel. He fixed that by removing the yellow plug from a spare bag and splicing it into it. Everything works flawlessly now.
What's kind of strange is he tested continuity on the yellow plug from the old clock spring and there was a reading on all the pins. So, I'm unsure why the original one was throwing an SRS code.
Thank you all for the help. Now I can finally finish this car and get her on the road.
Old May 8, 2017 | 11:44 AM
[EDIT]
Problem solved again. A simple factory reset turned the light off again.
danir
Sep 20, 2018 03:24 PM
whatsausername
Honda Civic (2006 - 2015)
Jun 16, 2009 02:55 PM
ToxicBug
23
Oct 22, 2005 01:23 PM
Curt941
Jun 27, 2004 05:25 AM
NeoGSR
Sep 11, 2002 07:22 AM
