Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
How necessary are these maintenance suggestions from the dealership?
Old Jan 20, 2016 | 06:53 PM
RPHaustinTX's Avatar
Default How necessary are these maintenance suggestions from the dealership?
Hello,
I own a 2005 Accord with 190K miles. The car is in the shop getting work done on a recall, for free. I asked for high mileage, multi part inspection to see what preventative maintenance is suggested. They've sent me these, and I am interested in any input as to what might seem necessary, and what I can skip to save money. I haven't inspected myself so I am not sure as to the condition of really any of this. Thanks for helping I know nothing about car maintenance
1)Engine leak (replace V-TEC solenoid) $290
2)Reseal Power Steering pump $500
3)Replace right engine mount $263
4)Alignment $99
5)Replace right rear shock $441
What are my risks, for example, of not fixing the high dollar ones?
Thanks again,
RPH
Old Jan 21, 2016 | 06:29 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: How necessary are these maintenance suggestions from the dealership?
4)Alignment $99
Thanks again,
RPH
1. Engine may not run or run in limp mode. It's not comforting if the check engine light is on.
2. I consider steering to be a safety issue. True, if power steering goes out, you can steer the car. But it will be very heavy. That sudden change could be a danger on the road if it's unexpected.
3. More engine vibration and loud sounds. Engine mounts can cause other problems, but I don't consider it a safety issue.
4. If the alignment is off slightly, it's ok. Maybe wear out the tires a bit more. You can be the judge on that. If it tracks ok, acceptable, I would not spend the $$$. Sure, it's off 1 degree, but you are trying to save money.
5. Again, you have to be the judge on that. If the shock is leaking, it still works. And you can wait on this. If the car is bouncing out of control, then it's a safety thing.
Of course, this is just my opinion, and maybe others will feel different. And I'm going off of how you are describing it.
In summary,
1-2 need to be fixed.
3-5 can wait.
Old Jan 21, 2016 | 12:46 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Hello,
4)Alignment $99
Thanks again,
RPH
None of them are maintenance items.
They are repairs.
They should be addressed when possible or will likely lead to more problems....
Old Jan 22, 2016 | 06:34 AM
Thanks for the advice, it has been helpful.
Go Pack!
RPH
ToTriggerHappy
Apr 13, 2011 05:17 PM
marylou
Aug 10, 2010 08:58 AM
vtec4max
Apr 4, 2008 08:24 PM
shortlid
Mar 13, 2008 09:05 AM
