Automatic Civic Problem ?
Old Jan 19, 2016 | 08:06 PM
necnext's Avatar
Default Automatic Civic Problem ?
Cutting to the chase, 1997 Honda Civic
when i floor the pedal the car takes quite some time before it actually catches a gear and moves. is this a problem ? certain times it catches on quicker than usual so i presumed it was a problem.
When driving normally around 20-30, pressing on the pedal is suppose to push the car, by push i mean pull you back in your seat alittle.
In the other cases it doesn't do it, it just drives and climbs very slow.
What type of problem is this?
Old Jan 19, 2016 | 08:10 PM
Former User's Avatar
Default Re: Automatic Civic Problem ?
What trim/engine?
Last tune up?
CEL codes?
Old Jan 20, 2016 | 12:39 AM
delsolintegra's Avatar
Could be as simple as draining and refilling the transmission fluid with fresh Honda automatic transmission fluid. Big neglected item.
Could be some other issue with a sensor that effects engine performance/timing, etc. Any check engine lights, codes?
Old Jan 20, 2016 | 11:03 AM
necnext's Avatar
D16Y7, Honda says its a Civic SE. Carfax says DX.
Last tune up, Not sure
There is no check engine light, as for as CEL codes.
Old Jan 20, 2016 | 01:01 PM
NotARaCist's Avatar
I never narc'd on nobody!
Does the CEL work? It should come on for ~2 seconds when you turn the key to ON(II), then turn off. "Not sure" is not a good sign. Give your car a full tune up. NGK spark plugs and wires, OEM (from the dealership, not "OEM type" from a parts store) cap and rotor, and fuel filter. Flush the coolant. If you really want to be an achiever, flush your brake fluid and check your pads, too. Then, more to the point of your symptoms, do a 3x3 drain/fill of your transmission fluid. Do not get it flushed - that'll free **** up from the filters and can wreak havoc on your transmission. Drain, refill with Honda ATF, take a quick trip around town, repeat 2 more times.
Your car will take care of you as long as you take care of it. Don't neglect basic maintenance.
Old Jan 20, 2016 | 02:33 PM
necnext's Avatar
yeah the CEL works and thanks, i will look into doing so and get back to you.
Old Jan 21, 2016 | 12:56 AM
Jimi Hondrix's Avatar
How long have you owned it?
Sevice records when you purchased it?
Stock engine and transmission?
As other's stated do an ATF (Automatic Transmission Fluid) 3x3 drain and fill.
Bleed/burp coolant. Pull spark plugs, take close up pics and post them.
Test spark quality before replacing any parts.
Ma7amed
May 24, 2015 03:55 PM
Lem Panganiban
Honda Civic (2001 - 2005)
Feb 8, 2012 12:52 AM
booba604
Nov 23, 2004 06:45 PM
