98 Civic coolant fan went out. My brother and I replaced the fan, still did not work. We replaced the entire radiator, thermostat, coolant temp sensor, radiator cooling fan switch, and fluid. Hooray, the fan comes on now.
The new problem: after doing all of this, I have the check engine light on. Took it to auto zone, and it is pulling the above codes. The car is now having a hard time starting (cold start runs at around 300rpm idle, and when I push the gas pedal it dies).
Any thoughts or ideas on this? Where did we go wrong?
Ok...hubby just checked for me. He said the all seem plugged in tight. He also said he put his hand over the open end of the air intake, it formed a suction, then ran fine. It did this last night too, so once it gets back to a cold start, the problem shows its face again. The codes never go away...even when it starts running ok.
All wires matched. So, this is what I tried: took the new ECT sensor off, put the old one back on...it worked. Running like my little kitten, and no codes. Funny how one little faulty sensor (even though it was brand new) can cause so many problems.
Thank you for your help today, so simple even this girl right here did it
