Which o2 oxygen sensor should I buy?
Old Jan 15, 2016 | 11:51 PM
joenobodyyet's Avatar
10 Year Member
Default Which o2 oxygen sensor should I buy?
I drive a 1997 Honda Civic LX Manual transmission and the check engine codes read that I need a new upstream o2 oxygen sensor. I was told that Denso is the way to go, but could someone please let me know which one I should get? What is the difference between the 234-4209 and the 234-4065? I also see a 234-4099 but I think that is for automatic transmission? How much should I expect to pay? I've seen some crazy oxygen sensors for over $100, then I've seen some generic for less that $20. If someone with more experience could provide some advice I would greatly appreciate it. Thanks!
Old Jan 16, 2016 | 06:33 AM
Former User's Avatar
Default Re: Which o2 oxygen sensor should I buy?
A CEL code can't tell you whether the O2 sensor is bad. Do the electrical troubleshooting outlined in the service manual.
Post these questions in the Value sticky.
Old Jan 17, 2016 | 01:44 PM
Bently_Coop's Avatar
Steve at Heart
Denso and NTK/NGK sensor's are OEM to Honda. I much prefer them for sensors, spark plugs and other electrical items.
Upstream:
More Information for DENSO 2344099
Downstream:
More Information for DENSO 2344065
Around $55 shipped for OEM equivalent parts is the way to go. If you use rockauto be sure to locate a 5% discount code.
Old Jan 17, 2016 | 05:34 PM
tony_2018's Avatar
Fish Twig
You buy the best that money can buy.
Old Jan 17, 2016 | 08:15 PM
raverx3m's Avatar
part finder from NGK website tells you exactly what you need to buy
PartCat
then go on ebay and find the 3rd from the cheapest lol
or go to one of these online stores:
autopartsway.com
partsgeek.com
Old Jan 18, 2016 | 09:01 PM
10 Year Member
Thanks, does anyone know what the difference is between the Denso 234-4209 and the 234-4065 and the 234-4099?
Old Jan 18, 2016 | 09:49 PM
Steve at Heart
4065 is post cat, 4099 is pre-cat and 4209 is only the sensor with out pigtail get the ones in links I provided and you are done.
I Am White
15
Apr 12, 2008 10:19 AM
cu3tip
Oct 18, 2004 08:26 PM
anothersickhatch
May 15, 2004 10:22 PM
97civicdx
Sep 3, 2003 12:49 PM
Phoenix_ITR
Jul 9, 2003 04:21 AM
