Rod bearing opinion (picture inside)
Old Jan 15, 2016 | 09:53 AM
carlos8's Avatar
Default Rod bearing opinion (picture inside)
Hi, I was changing my oil ( I change it every 1.5K ) when I noted some flakes on the bottom of the tray. I was using the car moments before no nocking no noise. The crank shaft is intact.
https://honda-tech.com/attachment.ph...1&d=1452883990
What do you guys think?
Old Jan 15, 2016 | 10:24 AM
96ekb20's Avatar
Default Re: Rod bearing opinion (picture inside)
had something go through your oil system. the biggest question is what do the bearings look like that are the top bearings thats where most your wear or inductions are to me made.
Old Jan 15, 2016 | 10:30 AM
carlos8's Avatar
This is one from the top.
https://honda-tech.com/attachment.ph...1&d=1452886237
Old Jan 15, 2016 | 10:36 AM
96ekb20's Avatar
what brand of bearing is it? how many miles is on the build
Old Jan 15, 2016 | 10:56 AM
Geis's Avatar
You wanna uh, give us some details on your build and why this is in FI?
Old Jan 15, 2016 | 11:17 AM
carlos8's Avatar
Ls Vtec, Piston rod combo, Turbo.
Stock block
JE 9.0:1 pistons
Eagle rods
OEM GSR oil and water pump.
King high Performance CR439xp bearings ( STD )
About 3-4 years not daily.
Old Jan 15, 2016 | 01:22 PM
LightningTeg's Avatar
Community Builder
At that age I would probably have the block cleaned and fresh hone / bearings since you dont really know if there is more debris in the engine somewhere.
n/a_kong
Jul 2, 2010 06:52 AM
bb4socal
Feb 1, 2007 01:28 PM
94-integra-ls
May 8, 2006 03:37 PM
svmnredracr
Aug 2, 2004 06:59 PM
GruvyTune
Jul 7, 2002 05:05 PM
