WTF is this clutch noise when I engage in 1st gear? :o(
Old Nov 6, 2002 | 01:07 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default WTF is this clutch noise when I engage in 1st gear? :o(
Whenever I'm stopped, put the car in first and begin to release the clutch, the errrrrk noise sounds. It sounds like the car is doing a mini-burnout, but the wheels are barely moving. I'm thinking the flywheel may be scarred up a bit from da NAWWWS, but it only happens when releasing the clutch in 1st gear. Everything is fine in 2nd, 3rd, 4th, 5th, and 6th gear. nah, no 6th gear. That would be the fizzle though. Any ideas? The clutch grabs fine. Clutch is ACT 6 puck w/ HD Pressure Plate, stock flywheel & FD. D drove it and couldn't really figure it out.
Also, my new Axxis Ultimates from Cobalt squeak like a ****. I'm thinking it may just be rubbing somewhere, but anyone else have squeakage? Andie w/Cobalt <----buy his products. He keeps calling me wondering if I figured it out yet. That's customer service at its best!
If you can help, you'd be the fizzle y0!
Old Nov 6, 2002 | 01:23 PM
TypRice's Avatar
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (RealTypeR)
a friend of mine has your clutch set up also and his does the same thing!
i have that same sound also in my R.
my buddy is a tech at the honda dealer(has been for about 6years),
he said that the honda crv had a similar problem and the tech couldnt figure it out!
finally honda figured it out.
it is the LSD fighting its self, when this problem comes up with there customers they change there trans oil to an updated version of there AUTO trans fluid!
call the dealer and find out if their was a new fluid for the car...
never mine im calling right now!
ill get back to you!
Old Nov 6, 2002 | 01:30 PM
TypRice's Avatar
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (TypRice)
ok i just called and talked to a sevice writer, he said that tere has not been any updates on the R... but he was pretty cool he knew me and he told me he will call me if he hears any thing!
if i find anything out ill let you know!
Old Nov 6, 2002 | 03:24 PM
d8168055's Avatar
if its the sound i think u are talking about,,, then its normal... i had that sound eversince i first got the car...
Old Nov 7, 2002 | 05:38 AM
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (d8168055)
TTT for the tech heads
Old Nov 7, 2002 | 05:43 AM
Paste's Avatar
Loved
hmm, mine makes a noise when i try to put it in while the car is MOVING, im unsure about your problem.
Old Nov 7, 2002 | 06:51 AM
Cosworth's Avatar
This problem with clutch can be adjusted. There was a thread about it a few months back. I think Shane (kengs) knows what to adjust to make the noise go away. Also, MiraiZ knows as well + other people. I know squat about clutch adjustment.
Old Nov 7, 2002 | 09:23 AM
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (Cosworth)
kengs where you at?
Thanks for nothing Sean!!
Old Nov 7, 2002 | 09:25 AM
Reid's Avatar
Global Moderator
Why aren't you using an "Xtreme" pressure plate with that 6 puck disc?
The HD pressure plate isn't meant to be used with the 6 puck.
Old Nov 7, 2002 | 09:32 AM
acuracy389's Avatar
New User
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (Reid)
I don't have an answer for you about this, but I have the same clutch setup and am taking it out because that noise is now in every gear. It sounds like a pig squealing. I'm going back to OEM.
-Heather
Old Nov 7, 2002 | 10:00 AM
forcefedb16's Avatar
Im using an extreme pressure place with my 6 puck and I get the same noise. I spoke with an ACT dealer and he told me this noise is totally normal and fine. Ive had the clutch in for almost a year and the noise has not changed.
Old Nov 7, 2002 | 10:04 AM
Reid's Avatar
Global Moderator
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (forcefedb16)
I have a 6 puck with Xtreme pressure plate that does not make this noise.
Though I tend to always pop the clutch rather than slip it.
Old Nov 7, 2002 | 10:12 AM
I only get the noise in 1st gear. Do you pop the clutch in 1st? If so do you get the unbeleivable wheel hop? If not what have you done to eliminate this. A little off topic I know but it is extremely bad.
Old Nov 7, 2002 | 10:15 AM
Reid's Avatar
Global Moderator
I do not have any issues with wheel hop.
Solid motor mounts are your friend if you want to eliminate wheel hop.
Old Nov 7, 2002 | 10:16 AM
I'm glad some other people know what I'm talking about. It's just sort of embarrassing when your taking a girl to lunch or dinner and she's like, "Is your car alright?" or "What's wrong with your car?"
Old Nov 7, 2002 | 10:31 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Does it make the same noise when its cold? After i get some heat in mine it starts squeeking.
Old Nov 7, 2002 | 10:33 AM
acuracy389's Avatar
New User
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (Rguy)
Mine happens in the winter and the summer, in every gear. It's so annoying.
Old Nov 7, 2002 | 10:36 AM
Kengs's Avatar
I guess Sean is referring to adj. the travel of the clutch pedal to alleviate noise; didn't do squat for my Cusco clutch (I guess due to the metal disk), but engagement is much better now
Old Nov 7, 2002 | 10:40 AM
It seems to be worse when the car is cold, but still squeals even when the car is warm.
Old Nov 7, 2002 | 10:42 AM
Reid's Avatar
Global Moderator
I'm guessing this is a trait of the metallic clutch discs.
Also I think the reason why I don't hear my clutch is because I run my car with an open downpipe. That slipped my mind for some reason.
Old Nov 7, 2002 | 11:06 AM
TypRice's Avatar
what else is he going to say!, no its horrible, take it out and return it!
Old Nov 7, 2002 | 11:21 AM
acuracy389's Avatar
New User
What ACT dealer did u call?
Old Nov 7, 2002 | 11:23 AM
Default Re: WTF is this clutch noise when I engage in 1st gear? :o( (acuracy389)
Local shop here in town that I bought the clutch from. Super compact performance.
Old Nov 7, 2002 | 11:25 AM
acuracy389's Avatar
New User
OK. I called ACT directly about this issue and the guys there told me they have never heard of it. (which in my opinion is BS)
Old Nov 7, 2002 | 11:42 AM
NWPNOMORE's Avatar
Banned
i can't stand the noise anymore from my clutch cause it's loud and I feel like I'm driving a piece of crap. I have the act 6 puck and heavyduty pressure plate. Hopefully there is a way to get rid of the noise.
