Brakes & Suspension Help Needed!
Hey y'all!
So, I daily a 1997 Civic EX. Said Civic has a pretty silly problem.
A couple months ago, I decided I'd r&r my front rotors and pads. At some point during the teardown, I realized the old front left rotor was a bit smaller than it's replacement... So I checked the other side, which turned out to be exactly the same size as it's replacement. I then took a gander at the calipers, which were definitely not a matching pair... Ugh. At this point I was a bit bummed out that someone, somewhere, at some point in time was a fool, and now I was paying for it. Oh well, I'll just order me up a new caliper! I decided, figuring it would be that easy.
The following morning, the new caliper was delivered. I excitedly requested some shop-time off the clock so I could get my brakes squared away.
Teardown completed, I grabbed the new caliper to mount it up. Well, as you can most likely presume, It was not a match...
It was at this point that I realized it wasn't just a mismatched rotor and caliper from side to side, but an entirely different steering knuckle. Initially, I wasn't keen on the fact that different trimmed Civics came factory with different sized brakes. Now I am.
tl;dr Though I may now know that different trimmed Civics did indeed come factory with different sized braking components (10.2"/9.4" ? rotors etc.), I do not know exactly which steering knuckle I need to purchase as a replacement. All I know is that I am fairly certain I need an EX steering knuckle.
Any helpful advice will be greatly appreciated!
We have a FAQ-your answer is there. Scroll down until you see:
https://honda-tech.com/honda-civic-d...ivics-1024818/
96-00 Civic EX or 99-00 Si knuckle. (51210-S04-N10)
96-00 Civic CX,DX,HX or LX knuckle. (51210-S04-980)
92-95 Civic EX, 94-97 Del Sol VTEC or any 94-01 Integra knuckle. (51210-SR3-N10)
92-95 Civic CX,DX,VX,LX,Si or Del Sol S and Si knuckle. (51210-SR3-000)
eH.
eH.
Last edited by eHMxhACk; Jan 15, 2016 at 09:30 PM. Reason: More correct information.
The calipers are physically different as well.
They also have a larger bearing/race/hub in the knuckle, I do believe.
Pickelz10
10
Jun 3, 2013 06:10 PM
