Ckf bypass diagram
Old Jan 14, 2016 | 07:49 PM
710dabber's Avatar
Default Ckf bypass diagram
Does anyone have the wiring diagram for ckf bypass i have 99 civic with 96 spec jdm b18c-r im currently running a p73 jdm ecu but i wanna get the check engine light off and when i run a p72 on there it throw vtec malfunction code and p1337 which is crankshaft position sensor which i have to do the bypass
Old Jan 15, 2016 | 08:01 AM
Verkmiester's Avatar
Default Re: Ckf bypass diagram
I just did this yesterday and I used this link (.:FFS TechNet:. » ECU & WIRING How-To Articles » CKF Bypass Trick), worked perfectly! Just make sure you cut the wires after the splice going to the sensor. The first article i found said to de-pin the wires and this didn't work.
Old Jan 15, 2016 | 09:03 AM
710dabber's Avatar
thank you sir
slimjim07
Apr 26, 2013 05:21 PM
MOVE OVER
Dec 29, 2005 10:33 PM
91tegrals
Nov 28, 2005 08:41 PM
onyx00
Aug 2, 2004 02:48 PM
