can a hydraulic clutch be adjusted?
Old Jan 13, 2016 | 02:43 PM
76 camaro car's Avatar
Default can a hydraulic clutch be adjusted?
I just acquired a 2001 accord with a standard transmission. The clutch does not engage until the pedal is almost all the way out. Can this be adjusted or do I need to replace the clutch?
Old Jan 14, 2016 | 10:04 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: can a hydraulic clutch be adjusted?
The pushrod on the MC can be adjusted for pedal free play(engagement),and the hydraulic portion of the system self adjusts for clutch wear.
Usually you do not need to adjust the push rod,but it is an option.
Old Jan 15, 2016 | 01:41 AM
Thanks, How is the push rod adjusted and how much adjustment can I expect to get? It does not clunk or anything going into gear but I think it needs to engage before the top of the pedal.
Old Jan 16, 2016 | 06:07 AM
poorman212's Avatar
You can loosed the lock nut then turn the push rod. Again adjusting the clutch pedal is usually not needed.
Old Jan 17, 2016 | 07:22 PM
Thanks, It may be ok. I was moving the car back and forth yesterday and it felt alright. Where the car is in my yard right now I only have about 10' to move it back and forth. Tomorrow I am getting a radiator for it and if I can get the air out of the power steering I am going to take it around the block. I will be able to tell more then.
Old Jan 18, 2016 | 05:23 AM
masospaghetti's Avatar
For what it's worth, I had the same concern with my 93 (high pedal) even after a new clutch was installed. I never had a problem with it until I ran the car into a concrete wall but can't really blame the clutch for that one.
Old Jan 18, 2016 | 05:29 AM
That's weird,This car was involved in a front end collision.
meece0927
Jul 2, 2013 08:15 AM
Kyle244R948
Nov 26, 2008 01:25 AM
Lola1219
Oct 12, 2008 02:18 PM
K2MSL200
Dec 17, 2007 02:05 PM
redman223
Jul 13, 2007 07:19 PM
