can a hydraulic clutch be adjusted?
I just acquired a 2001 accord with a standard transmission. The clutch does not engage until the pedal is almost all the way out. Can this be adjusted or do I need to replace the clutch?
Re: can a hydraulic clutch be adjusted?
Usually you do not need to adjust the push rod,but it is an option.
Thanks, How is the push rod adjusted and how much adjustment can I expect to get? It does not clunk or anything going into gear but I think it needs to engage before the top of the pedal.
Thanks, It may be ok. I was moving the car back and forth yesterday and it felt alright. Where the car is in my yard right now I only have about 10' to move it back and forth. Tomorrow I am getting a radiator for it and if I can get the air out of the power steering I am going to take it around the block. I will be able to tell more then.
For what it's worth, I had the same concern with my 93 (high pedal) even after a new clutch was installed. I never had a problem with it until I ran the car into a concrete wall but can't really blame the clutch for that one.
That's weird,This car was involved in a front end collision.
