Need help with rear wheel bearing
Old Jan 12, 2016 | 08:17 PM
Uljima's Avatar
Default Need help with rear wheel bearing
My rear wheel bearing is starting to go. I have a CTR 5 lug conversion in my EK with NO abs, however, I can use parts from the USDM ITR 5 lugs because they are the exact same. All of the USDM ITR came with ABS, so if I get a USDM ITR rear wheel bearing(comes with the hub doesn't come separated) will it fit into a CTR 5 LUG conversion with no abs?
That is what I am trying to buy.
2000 Acura Integra Type R Rear Wheel Bearing & Hub Assembly Driver or Passenger Side (Timken) at 1A Auto.com
says in the specifications "FITS MODELS WITH ABS ONLY"
*I have never dealt with abs so I don't know how they work, are they just sensors on the wheel bearing?*
Old Jan 13, 2016 | 06:34 AM
v4lu3s's Avatar
RTFM
Default Re: Need help with rear wheel bearing
It has a ring on the bearing/hub for the wheel speed sensor.
Old Jan 13, 2016 | 07:02 AM
Uljima's Avatar
So can it fit without the sensor?
Old Jan 13, 2016 | 10:01 AM
Uljima's Avatar
anyone else have some insites if USDM ITR rear wheel bearing with abs will fit on a ctr conversion with no abs?
Old Jan 15, 2016 | 10:16 PM
slowcivic2k's Avatar
Any ABS or non-ABS rear bearing will interchange in a given application. The only caveat is, if you fit a non-ABS bearing into an ABS application, a wheel speed DTC will be produced. The tone ring does not interfere with any braking components, and since the front wheels are triggered by the axles, nothing is noted here and there is no problem.
jason_SIR
Mar 25, 2014 01:49 PM
94boostedhatch
Suspension & Brakes
Jan 5, 2012 06:23 AM
EgonzEk
Feb 23, 2011 10:59 PM
youdontknowmeeither
Dec 20, 2006 08:50 PM
dat_flip
Jul 13, 2004 12:11 PM
