Lsv or gsr,?
Old Jan 11, 2016 | 08:56 PM
93eg_cody's Avatar
Default Lsv or gsr,?
Alright so im swapping out my b16 for a b18 dont know wether to go.. gsr or lsv.. I want power an torque, but i also want it reliable...? Any info,?
Old Jan 11, 2016 | 10:32 PM
KiNGDEE206's Avatar
Default Re: Lsv or gsr,?
Google is your key lol.
LSV if u build it CORRECTLY
GSR if u just wanna throw a stock swap in
Old Jan 12, 2016 | 08:05 AM
93eg_cody's Avatar
The shop i have my eg in is a reliable place and they build beast's .. Also life time warranty if something messes up ... but i want power, an also be able to use as my daily driver.. So idk weather to go lsv or straight gsr.
Old Jan 12, 2016 | 08:10 AM
Schister66's Avatar
Man U FTW
The only benefit of the GSR would be that you dont have to mess with it - its a straight drop-in swap. If you're building it, that logic goes out the window.
The reason people have issues with LS/VTECs is because they're shottily built by people who think they know what they're doing. If you build it correctly, its like any other engine.
My built LS/VTEC is still alive and well - its been together since 2009 and has been making 400+whp since 2010. Its all in how you build and maintain it
Old Jan 12, 2016 | 10:18 AM
93eg_cody's Avatar
That sounds beautiful man.. Congrats to your build and well i want power and something dependable at the same time cuz its ganna be my daily driver and well the motor is completly rebuilt 00 on the miles.. Brand new everything but i wanted to run lsv due to the torque and acceleration it has.. But they say gsr is more dependable built or stock.. Ima build it and boost it soon just gotta get the bills out the way.. So idk wether to go lsv or gsr.. And the guy im haveing build my motor knows what hes doing.. But i just dont know what i want.. I just need an opinion on what would be better..
Old Jan 12, 2016 | 10:53 AM
Schister66's Avatar
Man U FTW
Either one will do well on boost. If you're using stock components, they'll both handle the same power (roughly 3-350whp, depending on many variables). Ringlands are the weakpoint in either stock rotating assembly. If you're building for boost, choose a 4032 piston if this is going to be your daily....Reason being that 2618 expands more and with a greater variety in cold/warm weather (due to it being your daily), they have more piston slap and can cause excessive cylinder wear. Just my $.02
Old Jan 12, 2016 | 11:11 AM
93eg_cody's Avatar
Thank you i appreciate that.. Ima probably go gsr and when i get the money to buy the turbo then ill thro it on... And so if i go gsr i should buy those pistons right,?
Old Jan 12, 2016 | 11:42 AM
Schister66's Avatar
Man U FTW
That forging suggestion works for either LS or GSR, but again, building it (with forged pistons/rods) isn't required unless you're aiming for 350+whp. I'd focus on the here and now...get that engine together and running, then start with a stock block turbo setup, then build, increase power, etc....its all a progression.
Old Jan 12, 2016 | 11:53 AM
93eg_cody's Avatar
I already have forged pistons for it .. Just dont know if it needs anything else while its appart barrings rings gaskits everything is new,...an a new polished craink shaft .. The motor is in great condition just going to put it together and throw it in the EG hopefully when I get the money I'll buy a turbo for it and boost it but right now it's going to be my daily driver Just wanted some Power and torque but also wanted it reliable.. Its like a brand new motor freshly rebuilt hasnt even seen oil yet.. But i highly appreciate the Info .
93eg_cody
Jan 11, 2016 08:46 PM
s032105k
Jan 11, 2011 08:17 AM
Cripton805
14
Jun 26, 2010 07:32 AM
KGB_JDM
Jan 29, 2010 04:42 PM
azntuner
Jan 8, 2008 08:06 PM
