Jdm D15B cylinder compression?
Old Jan 11, 2016 | 07:58 PM
97DXHatchback's Avatar
Icon5 Jdm D15B cylinder compression?
hey all , i did alot of looking around for the cylinder compression for the jdm d15b motor and couldnt find a solid answer, lots of people got various results i seen as high as 200 across, i got 150 across accept cylinder 1 was 143 i havent done a wet test yet but i will soon as my alternator needs to be replaced, but im just curious if anyone knows what the d15b cylinder compression is supposed to be? its a 3 stage vtec i believe , as it has two solenoids next to the fuel rail any helps is much appreciated thanks.
Old Jan 11, 2016 | 10:25 PM
KiNGDEE206's Avatar
Default Re: Jdm D15B cylinder compression?
Super healthy psi all around (within 5% of each other) is 220-260 Psi
minimum healthy Psi all around (within 5%) 180-220
Bare minimum of psi to be considered ok (within 5%) 160-180 Psi
Going out compression i believe ~140 Psi
this is all my opinion and speculation
U say 150 Psi all around, that is on the low side for my taste, but im sure if u keep it as a daily (dont bang on RPM) it should last decently.
i consider my single bangers healthyness @ 180-240 Psi.
shooter93
Jun 17, 2009 12:12 PM
northcb7
Jun 8, 2009 12:31 PM
ntensehonda
Feb 5, 2009 10:34 PM
Convert
Jan 28, 2009 05:44 PM
arexniba
Apr 7, 2007 03:08 PM
