runs only with key in start
Old Jan 11, 2016 | 04:20 PM
wade280's Avatar
Default runs only with key in start
i have a 91 accord auto trans that will not stay running unless the key is held in the start position. if i jump b+ to either of the yellow or yellow/black wires it will stay running but have to pull wire to shut off. same with jumping at run relay. is key switch bad? thanks for the help, wade
Old Jan 11, 2016 | 04:47 PM
wade280's Avatar
Default Re: runs only with key in start
what holds the run relay in the run position? tried another relay with no luck
Old Jan 11, 2016 | 08:40 PM
TheMuffinMan's Avatar
He knows where you live!
My guess is ignition switch.
Old Jan 13, 2016 | 12:18 AM
MAD_MIKE's Avatar
MM Gruppe B
Ignition switch(electrical) is most likely toast...
$20-60 from RockAuto
Old Jan 13, 2016 | 03:36 PM
wade280's Avatar
from what i have tested that is what it is looking like. thanks,wade
88_hatch_ls
Sep 2, 2013 12:25 PM
cummins327
Dec 23, 2011 10:26 PM
91shelbydaytona
Dec 25, 2010 07:55 AM
thegrobe
Sep 3, 2009 09:30 AM
BlazeTeck2000
Dec 8, 2005 03:39 PM
