CT Allmotor k24 Eg hatch
Old Jan 10, 2016 | 06:11 PM
allmotor k24's Avatar
Default Allmotor k24 Eg hatch
Hi I'm selling my 93 civic hatch I've had it since 2009 it was completely stock when I got it, I gradually collected my parts and switched over to a k-series power plant in 2010. I ended up with a stock k20a2 complete swap while I was building my current set now which is a k20/k24 fully built. The car was converted into a race car and has weight reduction every thing was done by Kjbuilt and weights 1705 lbs. The car has always been tuned by Yosolo and is currently making 297 hp 200 tq on q16. This car can go deep into the 10 second range with some dailing in, the fastest the car has ran was 11.3 at 119 mph. I enjoy the car but do not have time for it anymore the price is $10,000 and I can be reached at 860-478-8390.
This video is from 2012 with a different setup
Engine
K20a2 head stock ports
Si industries valves std size flat top
Supertech valve springs and retainers
Drag Cartel stage 4 cams billet
Skunk2 exhaust cam gear
K24a4 Block
Wiseco 87.5 mm 12.5 compression Pistons
Eagle connecting rods
Acl bearings
Arp head studs
Type s oil pump modified with stiffer spring
Toda timing chain tensioner
Hpt chain guide
Engine is degree with proper specifications oil is changed every track event
Transmission
K20a2
4.7 final drive
New third gear and main shaft
07 Si differential 'Lsd'
Competition Clutch twin disc
Oem Rsx Type s 36mm axles
K-tuned billet shifter box
K-tuned shifter cables
K-tuned 5th gear lock out
R-crew shifter plate
Fuel
Vp q16
Injector Dynamic 1000cc injectors
Aeromotive A1000 fuel filter
Bosch 044 inline fuel pump
Hybrid Racing fuel rail
K-tuned -8 black braided fuel lines
FCS race pro series 1.5 gallon fuel cell mounts in front of the drivers side frame rail
Aeromotive A1000 fuel pressure regulator
K-tuned fuel pressure gauge
Air induction
Xcessive center feed intake manifold hand ported to 60mm
Q45 90mm tb
4 inch intake piping to 5 inches with vibrant coupler to 8 inch vibrant velocity stack
Suspension
D2 coil overs 10k front 12k rears
Energy suspension master kit
Hard race front upper control arms
Newer ball joints
Gsr rear disc brakes
Function 7 rear control arms gold
Function 7 rear subframe brace gold
Beaks bar gold
K- tuned traction bars
Stainless steel brake lines
Interior
Sparco steering wheel
Aem wide band
Recaro evo8 seats
G-force harness
JJW
15
Dec 27, 2018 08:09 AM
claysno
Jan 7, 2011 08:23 PM
flybert
12
Aug 23, 2005 02:18 AM
nY's FiNeSt
11
Aug 3, 2002 11:51 AM
