Fuel pump troubleshooting
Old Jan 7, 2016 | 01:50 PM
Brittain's Avatar
Icon4 Fuel pump troubleshooting
OK my fuel pump was not working I checked the maint relay and it check out fine, when I pulled the pump out to replace it I hooked it to my battery, and it still works fine. What else can I look for ?
Old Jan 7, 2016 | 03:30 PM
tim73's Avatar
Default Re: Fuel pump troubleshooting
With the tank on the ground, you can get to the pump wires easily. You can check to see if you are receiving 12V there when the key is in the on position. If you don't have 12V, then you need to check the ground. if it is good...then check the wiring back to the relay.
However, have you checked the ignition switch?
Old Jan 7, 2016 | 03:47 PM
Brittain's Avatar
Here's what I have tried, I have tested the main really by jump and checking for continuity. The relay check out fine. I jump the relay connector and colt tested the connector behind my back seat, it tested at 13.2V. I dropped the tank and pulled the pump housing out and wires it straight to the battery using the connector ontop of the housing and the pump works fine. Other than that I am lost... Thanks for the reply BTW.
Old Jan 7, 2016 | 03:48 PM
Brittain's Avatar
How do I check the voltage on the connector the connects directly to the pump housing?
Old Jan 7, 2016 | 05:23 PM
tim73's Avatar
Attach VOM to the two wired plug...coming from the car, that the pump plugs into. Then turn key to on, you should get 12V. If youre not getting 12V, I would suspect a control issue..ignition switch, or main relay etc. if you sure all controls are good...then get a wiring diagram...and go point to point checking continuity.
Old Jan 7, 2016 | 05:51 PM
poorman212's Avatar
Left out a key part here. If the key is turned to on....there will only be power to the fuel pump for about ~2 seconds. After that there will not be any power to the pump. So the OP should factor this into the testing.
Johnrb
Apr 29, 2012 06:05 PM
BBY98EX
Jul 20, 2008 12:06 PM
markD.
Aug 21, 2006 09:12 PM
b18-c-rx
10
Jul 17, 2005 02:10 PM
spencedogg
Aug 29, 2003 05:52 PM
