B20 swap
I bought a b20 and I'm ready to instal it to my ls integra. I'm using the same Ecu from the b18b it had. Someone told me I need to reuse the oil pump, do I really need to change the oil pump or can I leave the one that's already into the b20b
I believe this is what you are looking for
.:FFS TechNet:. » ECU & WIRING How-To Articles » CKF Bypass Trick
Your going to run lean unless you get a adjustable FPR. I'd recommend leaving the b20 oil pump the way it is and just get a P75 ecu off ebay with your b20 basemap. They can disable the crank sensor and rear O2, set launch control and idle speed.
-Tom
-Tom
